New Corvette Tool - Guess what it's for ?
Concocted this today on the lathe....
What do you think it does? I just tried it and it works great! Shoulda' done this 25 years ago. It's for 1953 to 1967, and maybe for up to 1975, I forget if the shark cars could use it.
Hint1: The hole inside is 1 1/4" deep, and it needs to be for a reason.
Hint2: It's NOT a hole punch.
Rich
p.s. For the impatient's, answer here in Post17
Update here with a video clip used on a C2...Post50
And the C2 (new and improved)design version here...
https://www.corvetteforum.com/forums...post1588834953
More info and video of a C1....
https://www.corvetteforum.com/forums...post1588817657
Rich
For installing wheels?
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Front shocks?
Fuel pipe bender?
What do you think it does? I just tried it and it works great! Shoulda' done this 25 years ago. It's for 1953 to 1967, and maybe for up to 1982, I forget if the shark cars could use it.
Rich
p.s. Taking off for a few hours to visit someone at the hospital and a bite to eat. Winner gets a prize.
Rich
Down into where distributor goes
put it on a drill and get the engine to get oil flow
Received 6,943 Likes
2015 C2 of Year Finalist
To push the inverted star clips onto studs
Okay, it was fun. Loved some of the guesses.
Here's the answer........Firewall insulation plug installer.....the opposite way.
For years, I've fought the firewall insulation installation. The factory had the luxury of 2 people to install the insulation rubber fasteners through the firewall. One pushing from inside with a special push tool, and one outside in the engine bay with pliers pulling the tip through. Since I work alone 99.9% of the time, some tasks are a pain to wait for help.
Rather than "Pushing" the plugs from inside the car, I decided to make a tool to "Pull" the plugs instead. I made a mockup using aluminum to see if I could get them inserted in the tool. It worked. So I made one up using steel bar stock, bored the center, drilled the end for a "pull hook" tool, and tried it out.
It worked great, even on the doubled up pieces.Here's how....(some various locations due to some pics being blurry)
Insert a narrow push tool in the fastener. Dip the rubber tip in soapy water.
Push the rubber tip, while stretching the leg, into the tool until it's all the way in against the rubber cap. It stretches 1 1/4" and stops inside the tool so it doesn't punch through the tip.
Insert the assembled tool and plug through the insulation and firewall.
Go in the engine bay, put your hook tool or a bar through the hole in the handle end.
Yank on the hook/handle tool, and the rubber leg stretches out until the tip pops free, and the rubber tip lands outside the hole and is secured in place.
Done.
Done.
