Engine temperature
Old 08-26-2014, 05:15 PM
Rayfry
Rayfry's Avatar
Default Engine temperature
I have a 63 conv. With a b.b. 454 in it. The car runs at about 210 degrees but when I'm in traffic it goes up to 220 degrees. Is this normal operating temperature or should I do something to bring it down to under 200. The radiator is the original that came with the car and the small block engine. Am I worried for nothing or should I replace the radiator with a b.b. Radiator? I don't want to make changes if there isn't going to be a big improvement.
Old 08-26-2014, 06:43 PM
Nowhere Man
Nowhere Man's Avatar
Received 6,920 Likes on 4,770 Posts
2015 C2 of Year Finalist
That is border line normal. Have you read the cooling articles written by JohnZ?
Old 08-26-2014, 07:25 PM
jim lockwood
jim lockwood's Avatar
Received 6,507 Likes on 2,996 Posts
C2 of Year Finalist (track prepared) 2019
I, for one, am genuinely impressed that the SB radiator can do as well as it does with your 454.
Old 08-26-2014, 08:52 PM
Gary's '66
Support Corvetteforum!
Gary's '66's Avatar
That, and the fact that the OP said its original! If it were my car I'd be putting in a nice new DeWitts BB radiator.
Old 08-26-2014, 09:01 PM
65GGvert
65GGvert's Avatar
Received 3,206 Likes on 2,297 Posts
I wonder if he meant the "original that came with the car" when he bought it, and not when it was built. He may have bought it last week.
Old 08-26-2014, 09:07 PM
Rayfry
Rayfry's Avatar
The radiator is the original factory.
Old 08-26-2014, 09:13 PM
65GGvert
65GGvert's Avatar
Then I'd say it's doing the best it can do. 220 isn't terrible, but I'd be prepared for a leak to spring up inside that radiator about any time.
Old 08-26-2014, 09:29 PM
Rayfry
Rayfry's Avatar
Thanks for the info guys. I'm going to up grade the radiator when I get the chance. I have a few other things that are in need first. The B.B. DeWitts sounds like the way to go.
Old 08-26-2014, 10:25 PM
tjstarduster
tjstarduster's Avatar
Default overheat
Buy a 4 core BECOOL replacement radiator and drop the temp down to 160-180. Heat is the enemy of the BB Chevy.
Old 08-27-2014, 10:24 AM
Avispa
Avispa's Avatar
You may need to use a '65 396 radiator. A 66 or 67 radiator requires a different radiator support.
Old 08-27-2014, 12:57 PM
Gary's '66
Gary's '66's Avatar
Yeah, didn't think about that. There were no BB cars in '63. Would a BB rad even fit?
Old 08-27-2014, 03:13 PM
jim lockwood
Yes it will fit but you have to replace the SB radiator support with a BB radiator support. The means of support is different for the BB radiator and it inclines at a steeper angle.
A 396/L88 radiator also requires a different support. Although visually similar to a SB radiator, it is wider and the core support has a larger opening for air flow.
Jim
Old 08-27-2014, 03:29 PM
Mr D.
Mr D.'s Avatar
Received 1,479 Likes on 1,000 Posts
The cheapest way out is to use a 1966 427 radiator setup; core support, radiator, fan shroud, clutch and fan, headlight opening support rods & hardware etc.
About $1,500 in parts.
Old 08-27-2014, 06:32 PM
Rayfry
Rayfry's Avatar
Dewitt sells a b.b. Radiator that will fit the 63 with a few modifications. Mostly just moving the horn relay and voltage reg.
Old 08-27-2014, 07:27 PM
Mr D.
Mr D.'s Avatar
That fits in a small block core support and shroud?
Old 08-27-2014, 08:38 PM
jim lockwood
?? How does that work???
Old 08-27-2014, 08:48 PM
histoy
histoy's Avatar
DeWitts also sells a direct fit radiator with 1.25" tubes, which is an increase in size from what you now have. The number is 1249063M (painted black). $680. You might want to talk to them, as it's suppose to be for performance engines.
To Engine temperature
Old 08-27-2014, 09:02 PM
0Tom@Dewitt
Former Vendor
Tom@Dewitt's Avatar
All these packages are designed to mount on the sb pins
http://www.dewitts.com/collections/ls-modified?page=2
Old 08-27-2014, 09:16 PM
jim lockwood
Interesting, Tom. Isn't the radiator wider than the opening in the support, though?
Old 08-28-2014, 12:26 AM
Thorson
Thorson's Avatar
C2 of Year Finalist (appearance mods) 2019
220 in traffic with lots of sitting and idling time is pretty good actually. 210 when you are at speed for a while is a little high but still not really a problem. I'd put the cooling on the back burner if you have other items you want to do with the car.
Quick Reply: Engine temperature
