1966 Original Distributor Cap
As stated above. the top of the cap says "Delco-Remy, Patent Pending". There is no "R" or long part number. The box for the correct cap simply says #D308. The matching rotor is #D409. Again no "R"…..as this describes a later revision.
Very good reproductions are also now available for this cap, at about 1/3 the cost.
Larry
yes, but like most repros, there is a minute difference from the original that is easily observed. Right next to the points window.
For the $$ versus the $$$$ for an original cap, many prefer to take the couple of points hit in judging.
Larry
If you re-set your odometer to zero after restoration and now have 10,000, 20,000 or more "original" miles on the car, couldn't you play along and say "the car's only been tuned once every ten years, the Delco cap on it was purchased from my Chevy dealer in 2006"?
Delco-Remy #D308.
Larry
Larry
Thank you Larry
