How to identify original 4 speed in a 58 ?
Read the Noland Adams book on this, it has alot about the shifter assembly in RPO 685- 4 speeds but doesn't give any numbers to look for on the trans to id one original to a 58.
Can someone please let me know the casting number & where it can be found, also any other info that will be helpful in determining if a 4 speed is correct for a 58.
Received 1,857 Likes
Main case will be a T10-1
Tailhousing will be a T10-7A
Side Cover will be a T10-148
There will also be a stamped assembly date code on a machined surface on the main case adjacent to the rear of the side cover.
A '58 T-10 will have an iron main case and an aluminum tailhousing.
Tom
Thanks guys !
