1966 p/w switch
1966 p/w switch
hi,
i picked up a 1966 a/c coupe. my question concerns the p/w switch. when i push the switch for the driver`s door window forward, the window goes down. on passenger side, push the switch back & window goes down.
shouldn`t each switch when pushed to the rear of the car make both windows go down? are wires crossed on one of the motors?
thanks,
bill
thanks,
bill
hi,
thanks,
bill
thanks,
bill
switch
If the drivers door side switch moves the passengers window and vise-verse, I think the switch assembly might be turned around. It is not keyed, so I think it could be installed backward in the console. If it is, pushing the passengers sw. fwd. would make the drivers window go down. As stated in an earlier post, the PW's should work with the key off.
Bill88 - Have you lifted the console and looked underneath? The PW wiring harness has a single connector that presses onto the posts of the PW switch in the console. That's the normal situation. But, if 'Bubba' has been into your midyear like mine, it will look something similar to this where they actually soldered each wire onto each post. In my case, they put the right wire on the right post and it functioned correctly (but since corrected), in your case, unless the switch is the culprit, someone might have gotten the wires crossed up. A long shot but a possibility.
Mike T - Prescott AZ
drivers window ok pass window only occasionally found plug had come apart plug wires loose nothing holding wires in plug piece of black tape laying under plug possible fire hazard venders sell mini harness to splice in
There is a small tab in the center of the individual flat brass terminals that go into the connector that plugs into the motor. This provides the locking function. If it is not fatigued from prior bending, you can carefully bend this small tab out approx. 20 deg. from flat so it will again lock into its socket. The wire must have terminals crimped on the end. If there are just bare stripped wires the terminals may be still in the harness connector plugged into the motor and the wires were pulled out of the terminals. then you will need new pins.
SI67 - Yes, the motor end of the PW wiring harness has what I'd call 'barrel-shaped' connectors. There are two terminals in each connector and they are placed in a 'T' configuration. They can only be attached one way.
