Coil and Fuel Pump recommendations?
Looking for recommendations for a new coil and fuel pump for my '67 C2 w/ 300 HP 327... It was driving fine for the trip to the DMV (for other matters) and after sitting there for 2 hours it was driving fine for most of the way home, maybe 10 miles. Then it was acting fuel starved (run for a second, then dies, etc.) until it died. After sitting for around 15 minutes - actually me alternatively looking at the carb like I had any idea what was going on and cranking the engine - it started up and I got home. There was one more incident a few miles after I got it restarted, but it started almost immediately and ran fine the rest of the time.
The fuel tank is pretty clean, so I don't think there was garbage in the line. The coil and pump are old, so I thought I'd start with replacing those and see if I have the issue again.
I saw a lot of coil and pump options on Amazon. Does anyone have a favorite of either and a reason why?
Any other thoughts?
Any other thoughts?
Any other thoughts?
Any other thoughts?
Get a test light and go for a ride around the house to get it good and warm until it quits then see if there is power on the coil + terminal while cranking as that will give you indication if you have a fuel or electrical problem.
Instead of throwing parts at it why not try to find the real problem and repair it.
Check your fuel filter/air filter first I would think.
The coil and pump are both ancient and cheap to buy so I figured I start with those. I'm thinking coil too. The air filter is brand new, but I'll check the fuel filter. If anything, it felt like a temporary blockage of fuel (like a big chunk blocking the line, then moving out of the way). Or no spark... The rest of the ignition system is new.
Any thoughts on which coil though? Amazon has several options for my engine.
The Napa IC-12 or is it IC-14 is a great coil, that's what I put on my 63 corvette. Don't buy the reproduction stuff, it's junk and don't throw your hard earned $$ at parts that are not bad.
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
If you have the original 1967 40433 fuel pump it's a one year only part so don't be in such a big hurry to get rid of it.
Received 1,858 Likes
