Oil Pan Drip
Oil Pan Drip
Hello All: Last night, when I pulled my car out, I noticed a small pool of fluid on the garage floor (not sure how long it's been accumulating). Tonight, when I got home from work, I crawled underneath to have a look. There was a drip clinging to the drain plug of the oil pan. Okay, it's oil. Drain plug seems tight enough. Checked the dip stick and it showed (cold engine) a level slightly above "Full." So Kerouac's idiotic newbie question of the day is -- can the drips be originating from the top of the pan (due to it being over-filled) and just running down to the drain plug? Below are two pictures. Thanks.
NO...
Tighten/check all pan bolts...
Next time you change the oil put on a new plastic washer on the drain plug...
That's a interesting oilpan. Very deep, and the drainplug is on the bottom of the pan for Corvette, not like that. Not sure what year you have but based on your avatar a 3 or 4?
I see a line of oil above the drainplug, so it may be the rear pan seal or gaskets, or .........I hate to say it, possibly the rear main seal on the crank.
Wipe the rear of the pan and around the plug. Run the engine to temp for a while and try to see where it's coming from. Also check the block sides at the rear, as it may be coming from rear intake manifold to block seal or valve cover gaskets.
BTW, that pic of the oil on the floor looks like the floor under the wife's Jag V12 E-Type. On those, if it doesn't drip oil like that, it means there's no oil in it.
The Oil filter looks brand new, might check to be sure there is only one gasket on the filter. Sometimes the old gasket sticks to the engine and does not come off with the filter. They usually blow out and lose all the oil not long after install. You have quite a bit of oil on the floor. Over filling does not normally cause a leak.
Thanks, Guys
It's been madness at work, so I haven't been able to respond individually. So here's the update: Tried to tighten the plug, but it wasn't having any of that. I had wiped down the area where the drip appeared, and tonight there was no additional oil evident. I guess I'll just keep an eye on things and see what develops. Thanks again -- I appreciate the help.
Steve
