Por15 chassis coat black
Just recently purchased a can of chassis coat black (aerosol) by por 15.
Painted a few small parts and was very impressed. The paint is very durable and has a very nice satin finish.
I'm almost ready to start painting the engine compartment on my 58, Im using SEM for the firewall and inner fender and Por 15 for the frame with a top coat of the chassis coat black but I started thinking do I really need the Por15 as a base? I have no rust issues and the chassis coat black is very durable?
Received 6,943 Likes
2015 C2 of Year Finalist
If the POR15 is any thing like I used I would throw it away
Sorry guys but have a lot of experience with POR-15 and it is not a rust converter. It is a neutralized rust encapsulater. The key being that you need to remove as much rust as you can and then phosphate wash the metal to neutralize it first and then apply the POR-15. Now to the OP's question I would not use POR-15 as a base for further painting as that is not what it is for. A self etching primer is the correct coating if you do not have rust issues once the metal is exposed. POR-15 will encapsulate old paint pretty well but the surface needs to be sanded well to make it look good.
phosphate wash
The part I painted yesterday with the aerosol por 15 chassis coat dried rock hard.
I tried to scratch it off with my finger, no way! Perrsonally I think this paint is great.
I'll pick up some por15 self etching primer for my frame.
Thanks !
Thanks !
But - all things being equal I think I would use the Eastwood Chassis Black instead.
