C1 Steering
2nd Gear
C1 Steering
I have a 1958 Corvette and am seriously considering replacing the old original steering with the "Steeroids" rack and pinion assembly. Has anyone with a C1 done this swap?? I am looking for opinion or ideas before I undertake this project. Cost of kit is $2000.00.Thanks for any feedback.
O
O
Don - Welcome to the Corvette Forum. There's been quite a few threads on the subject of Steeroids and other front suspension/steering mods for solid axle Vettes. Click on the red Search box on the right upper side of the screen and check out the archived posts on the subject.
Mike T - Prescott AZ
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
Don,
Echoing Mike, welcome to CF. Good info here.
While I don't own a C1 with the Steeroids conversion, I've driven one. I found the steering to be overly sensitive. It took near total concentration just to stay in my lane at hiway speeds. The experience was not relaxing.
Admittedly, it's possible the owner did not re-adjust toe-in after the conversion and that the tires were actually toed-out slightly. I don't know. I did share my observations and recommended he have it checked.
Based on this one experience, though, I'd rather have the original steering box in good condition than the Steeroids conversion.
BTW, decades ago I lived in West Columbia. Every time I'm back there I make it a point to go to Maurice's Piggy Park .... best bar-b-que in the nation.
Jim
Jim
Don,
Jim
Jim
Was that C1 with power steering or manual?
The PS rack & pinion (TCI front end) that WMF62 put in his 62 was very sensitive, until he dialed back the pump output.
If I was to put in a R&P, it would be manual. But my biggest issue with the Steeroids (and similar systems using the Ford R&P) is the need for 3 U-joints to connect the steering column if you have headers (and the column shaft snakes through the headers, not around).
Thanks,
Plasticman
O
O
for me it really improved my enjoyment of the car. I have had my 1961 car for nearly 36 years.
Very quick and precise steering, you can drive it like a rental car. The old system probably seems like a crappy 49 chevy because it is! These days we just arent used to driving and parking non ps cars.
America is not the wide open place it once was, we were used to not trying to move the wheel unless the car was rolling, parking was more like docking. Just a preference but in todays modern cities, small spaces, small cars, congested streets, I just like it. The steeroids deal looks well done. Search around a little and tell us what you think.
Jim,
Thanks,
Plasticman
Thanks,
Plasticman
John,
The car had power steering. As I drove, I tried to separate out the sensitivity of the PS servo from just a general twitchy nature. I'm pretty convinced it wasn't PS sensitivity. The car simply would NOT go straight.
Regarding Bill's PS sensitivity, I'm curious.... why not replace the spring in the servo with a stronger spring to reduce sensitivity? Restricting pump output strikes me as the wrong way to go.
You are a EE, aren't you? Let me make an analogy: That pump, being a positive displacement pump, is a "current source", the instantaneous current flow is a function of engine speed. Add flow "resistance" and the "current source" output "Voltage" is going to rise to whatever value is necessary to maintain "current" flow. I'd expect that it's possible for the "Voltage" to rise high enough to break down the "insulation".
In English, if pump flow is restricted, internal pump pressure could rise and burst the pump (or whatever is upstream of the restriction).
Or I could be all wet.....
Jim
John,
Jim
Jim
I agree with what you are saying, but it was a question at the time of "What did other guys do?", and try that.
Bill is off on another of his trips, and I cannot remember exactly what he finally did to the pump.....but I know he did use some restrictors and perhaps a spring in the pump output at one point.
Sounds to me like you nailed it with being an alignment issue on that C1.......
Thanks,
John
Don,
Jim
Jim
Marc in Indy
