rear axle code
rear axle code
Hello Putting together a drive 65 roadster .pulled rear end out C clip had come off side shaft ,anyway RH side #3818767 N LH #E274 Is this rear out off a 67? What's the ratio? thanks Gregg
The number and letter prefix that you need are actually located on the bottom of the case just forward of where the spring bracket is located. The two letter prefix tells you the ration and the rest is the date.
2016 C2 of the Year Finalist
There was no AK code for a 64 date according to my Specifications Guide. The code for a 64 standard/non posi differential would have to be CA, CX or CZ. Are you sure you read the first two numbers correctly? Could the number 64 be a 65?? One or the other seems to be incorrect.
AK code was available beginning 65 through 69 according the guide I have and was a 3:36 non posi unit.
But being a sept 64 date, it could be a very early 65 AK 336 non posi.
Edit, corrected code to AK
My Sept.1, 64 has mostly Aug. (H) dated '63 parts. I should have read the post and the date a bit closer!! Dave
