67 side pipe cover will not stay on??
I am sure others have dealt with this. I have a 67 that has aftermarket headers and original pipes and covers. Pipes were modified to connect into headers and work great. Issue is side pipe cover on passenger side. Anytime I hit a good bump it slides right off the c clips are simply not enough to hold in place. I hope others have encountered the same problem.
Help
Help
Moderator
C clips on side pipe covers? The covers are bolted at the rear via a bracket and screwed onto the front inner fender, then screws all along the length of the body under the door. I don't understand sir.
maybe the holes where the clips attach are broken out and slide down and out of postion??? send a picture without cover on and also of what you call a C clip, better help suggestions that way.
Update
Thanks for the notes. I will take a picture this evening but the side cover attaches in front wheel well and rear through the mount that holds the side pipe so two contacts. Those two contacts do not provide enough support to hold it in place. Along the rail just below the door there are six Vs to which there are C clamps or nuts that hold the cover screws into. Any type of heavy bump and the cover and clamps slide right off. I think a picture is worth a thousand words on this so I will get one
Received 1,856 Likes
Here's a photo of one of the birdcage notches with side cover installed showing the U-nut and machine screw installed, easy to see with side pipe removed
No problem
Glad to help!
Thank you - Thank you
Exactly the picture I was looking for. Makes sense as to why the c clips that were being used will not hold. I just could not figure out why and now I really cant figure out why somebody cut the Vs in the fiberglass. Clearly they used a template because they are all the same size.
Thanks again - I ordered the correct parts last night and will be doing a little fiberglass work this weekend to fill the holes.
