Redline tires
Redline tires
I have a 67 big block and just bought a set of repo bolt-on wheels to replace the Cragars on the car now.
The plan is to get a set of redline radials.
I've looked at Coker and Diamondback. I prefer the Diamondbacks but am concerned that because they have to modify/shave the tire to apply the redline, this will weaken the tire.
Questions:
1. Can someone address my concern about the potential weakening of the Diamondback tire?
2. Size: I'm thinking of 215/70/15 to get more tread on the road as compared with the 205/75/15 which I believe is the size tire that came on the car when new. My goal is to have a low profile stance and good performance.
Any suggestions? Comments? Advice?
Thanks!!!
Questions:
Thanks!!!
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,321 Likes
While not on a C2, Ive yet to have problems with 3 sets of Diamondbacks.
Diamondback will not weaken the tires. They just removes the writing and smooth out the outer suface on the tires, and then add the red line.
Received 4,543 Likes
2016 C2 of Year
2015 C3 of Year Finalist
I have Diamondback redlines on my 68, gold lines on my 65 and ww on my 61. Many miles of driving with no issues. I don't believe their process weakens the tires in any measurable way.
Enjoy while you can.
Received 2,684 Likes
Ohio Events Coordinator
C2 of Year Finalist (stock) 2019
St. Jude Donor '14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Here on the forum, Diamondback is preferred over Coker by a good margin. I switched from 205/75 to 215/70/15 several years ago with no regrets.
Cookers don't stay red. Just like their white walls don't stay white. I asked their rep at a show Coker attended and he just shrugged his shoulders telling me to use a good cleaner.
Diamond Backs hands down!
I have used both Diamondback, on my Corvette and Universal Tire on my GTO. I'm very satisfied with both companies. Diamondback makes the tires on order and they take a longer time to arrive. Universal keeps most sizes stocked. FWIW
Joe
Joe
Diamondback doesn't supply Michelin redlines anymore in the 205-75 size. The 215-70 Michelin based are 26.6 and 6.8, so taller and wider. They do offer Toyo based redlines, but the tread width is only 5.3 inches in the 205-75 size. The 215-70-15 shows 26.9 tall and 6" wide, so if you go with diamondback, that would be closest to what you describe. I'm not going by the charts, they still show the Michelin available in the correct size. I spoke with them directly to order and they told me Michelin no longer makes the 205-75 tire.
As far as the Coker not staying red, that's just not true.
10 yr old Coker
I have coker wide whites on my 61 for about 7 years, still white, but they took a lot of lead to balance.
I have diamondback redlines on my GTO. No complaints. Plus diamondback are good people to deal with.
https://www.corvetteforum.com/forums...se-1965-a.html
https://www.corvetteforum.com/forums...-question.html
I'd like to point out again that according to Diamondback and the Michelin website, Michelin no longer makes the 75 series tire, either in 205 or 215-15. To get close, you're going to have to use a 70 series tire.
But the 215/75/15 is available in a Toyo brand.
please note my mistake, I have 215/70/15
Just ordered a set of 215/70/15 Michelin Redlines from Diamond Back. Spoke to Bill and he was super friendly and knowledgeable.
Looking forward to mounting them on my bolt-ons and putting them on the car!
Hopefully you will post back how the fit works out for you? I am trying to decide the same fitment as you have. I'm concerned that the wider size might rub on the front in a tight turn.
So he also told you the Michelin was not available in a 75 series even though the catalog listed them? I also called him last week for the same reason and I was trying to help by letting you know that you would have to use a 70 series if you went to Michelin.
Hopefully you will post back how the fit works out for you? I am trying to decide the same fitment as you have. I'm concerned that the taller and wider size might rub on the front in a tight turn, as well as affecting the speedometer accuracy.
Received 1,856 Likes
