64 Turn Signal Cancel Issue
64 turn signals only self cancel on very sharp corners/turns but not on most regular turns? Is this a bad turn signal switch, canceling cam, or likely something else. Everything else works fine.
"Very sharp turns" may be too vague for a correct answer, but you may find that it's working the way it came from the factory. Specially if it is about the same amount of turn each way it takes for it to cancel. I'd just give it a little bump before I started changing parts, but that's just the way I am.
Received 1,044 Likes
C2 of Year Finalist (appearance mods) 2019
Is it the same left and right? It may not be clocked in the correct spot there is a stamped line on the shaft and on the steering wheel hub with wheels straight the lines are at 12 O clock, or there is some pcs missing.
