1966 427/390 #321 block
I just purchased a complete 1966 390HP engine with a 321 CE block dated Dec. 1968. 3872702 heads, 3880827 & 3880828 exhaust manifolds, 3866948 intake manifold. All have 1966 casting dates. The crank has a 6223 stamped on it. It comes with a fan, pulleys, "444" bell housing, alternator brackets, fuel pump, distributor, water pump, oil pan, valve covers, and non original dual line Holley carburetor.
It is standard bore honed and new rings, new cam, rod and main bearings, new oil pump, new comp cam and lifters and springs, crank has not been turned. I was told the valves were lapped, but may need guides. Of course I will tear down to inspect and verify.
My question are:
How rare is a "321" block?
Is "444" the correct bell housing for 1966?
Is "6223" the correct crank number for 1966?
I would like it stock except for an aluminum intake and a cam with a mild lumpy idle. Any suggestions???
And finally, what is the value?
My question are:
Received 1,919 Likes
You say it's a 1966, but also say it is dated Dec 1968?
FWIW.
Received 1,048 Likes
C2 of Year Finalist (appearance mods) 2019
They are not at all rare, the blocks that are hard to find in good condition is one dated for a 66, the 321 block was not ever used in 66, there where a lot of replacement blocks in 66 the rod bolts where still coming apart. The 444 bell is correct, 702 heads are correct but also used in chevelles. The crank is a forged crank for 427 and also 396 chevelles, a lot of the 390 parts where 396 parts, intake included was used for 396 325 HP with EDH code and all 360 HP.
Not real rare. That's what is in my 66 - with 4-bolt mains.
Received 6,943 Likes
2015 C2 of Year Finalist
Received 1,857 Likes
Value is what someone is willing to pay or what one could expect to get in parts alone.
My guess is not more than $3k
If I could have bought a 427 long block for 3K I would not have a 396 in my Chevelle. 5-6K is what I see people asking and selling
I'm also not talking a ready to drop in rebuilt motor for $3k, for that you would need $5k.
No 5-6K gets you cores to rebuild where I come from
