Under Carpet Heat And Sound Insulation Vendor
Last year there was a vendor who just started selling C2 under carpet heat insulation (a die cut kit for the front) and then additional bulk for the rear. I couldn't find it in the archives. Ring a bell with anyone here ?
Ray
Ray
Ray,
The Dynamat Store sells custom cut underlayment for C2s if that is the type material you are looking for but it is expensive. If you are looking for the original rubber backed jute material Corvette America has it pre-cut. When i did mine I used Frost King Duct Insulation from Lowes or Home Depot. It comes in rolls of 1' X 15' and 1/8" with a adhesive backing. You have to cut it yourself but save beaucoup bucks.
Don
Don
Under carpet
The company was Vettenuts.net. I remember seeing it as well
insulation
vet nuts...nice die cut..sound dampener one side foil on the other every thing labeled and fits super nice and the labels help with install...Mark @ VET NUTS on line
Supporting Vendor
St. Jude Donor '11
We have them located here and on sale for $125: http://www.vettenuts.net/index.php?l..._detail&p=1041
We highly recommend adding the Premium layer for more heat and sound protection.
I installed it without the premium layer in my 63. Mark also sent me some extra pieces to put inside the doors. I never drove the car without so I don't have a real fame of reference, however I was happy with the installation and am also happy with how it appears to control heat. I installed Knock carpet over the insulation, looks & fit well.
AB
AB
Ray,
Don
Don
I used Hushmat and the original jute mat and I have been very happy with the heat reduction... I just did the firewall back of the seats. I would be inclined to do the rear because of the drone but after three years it has not been enough to make me pull out the carpet....
Hitch
Hitch
We have them located here: http://www.vettenuts.net/index.php?l..._detail&p=1041
I found it under "C-2 Insulation kit" on their site. 165 dollars. No listing of "R" value... Paragons kit is 1/8 thick and 138.00 bucks..
Supporting Vendor
St. Jude Donor '11
I just put the kits on sale for $125!
Here are the specs on the material.
polyethylene backing
closed-cell Polyethylene foam
Aluminum Foil
Characteristics | Value | Regulation
R Value 16
Cell Structure: Closed
Nominal Thickness: 5 mm (+ or - 0.5mm)
Steam Permeability: 0.033 gr/m2hkPa ASTM E-96
Noise Insulation: 19dBA IRAM 4063 at 50hz.
Flame Spread Index/Class: 25 or less/ "A" - Class 1 0 ASTM E-84
Smoke Index/Class: 450 or less/ "A" - Class 1 15 ASTM E-84
R Value 16
INSULATION LAYERS
Aluminum Foil polyethylene backing
Aluminum Foil
Aluminum Foil
R Value 16
R Value 16
INSULATION LAYERS
Aluminum Foil
Supporting Vendor
St. Jude Donor '11
Yes its $280 for the Premium Kit. We add the Ensolite on top of our standard foil kit. It makes it one kit, we simply add another layer. Our Premium kits are our # 1 seller. We sell more for the C5/6 generations and there is a lot of feedback in our for sale threads along with customers who have posted after installing. It makes a huge difference adding the Ensolite. The kit for $125 is a great kit especially for the money. It took me 8 hrs to make all the templates for the individual pieces. This saves you the customer hours of cutting and trimming and wasting material that still does not fit 100%.
