Help no oil pressure !
A little background, I just added the correct intake so the manifold was off and the distributor was out and reinstalled after the intake was in place, car was started and timing set with no issues, I can't say I am 100% sure I checked the oil pressure at that point but believe if it was low I would have noticed it as it is a usual check after any motor work. So while I was working on the car I replaced the oil pan and used a 1 pc. gasket to stop a front seal leak, the pan was from Summit and I used the gasket they recommended for it. It seemed a little snug at the rear, meaning it did not just slide into place but it was not something that had to be forced, I believe it was the blue pins from fel pro that were a bit too snug going thru the pan bolt holes ( they were left over from another gasket kit from past work as there were none with the new gasket. It definitely did not seem like it was hitting a hard stop. I got all of the hardware in with no issues and completed the reassembly. I added a new filter after verifying that the groove for the canister gasket was clear, there was one stuck in the groove that I removed, I assume that there should be no other o ring or gasket in the grove other than the new one that is installed with the new filter. Added 5 quarts of oil and verified the level on the dipstick started the car and no oil pressure shows on the gauge, it normally carries 30# to 35# at idle and 55# to 60# at cruise rpms. I show 0# nothing at all, so just looking for suggestions, my plan is to remove the line from the gauge and make sure it is not plugged by blowing air through it, if that does not do it I will add a new gauge at the fitting on the motor to verify that the gauge is good ( it never showed any issues before ). If none of that works my next concern is if there is a chance that the oil pick up is against a surface that is not letting it pull in the oil, remember I said it did not fall into place... I did verify the depth of both pans and they are the same and the internal baffling looks similar in placement so I don't think it's an interference with the pick up but worth a mention. I did not let it run for long when I saw there was no pressure so maybe I did not let it run long enough ? it had been sitting unstarted for at least a week. Sorry for the long post but I want to take the right steps as this is the correct engine for the car so I don't want to hurt it by doing something stupid.. Thanks for any help you can offer.
Jim
Jim
Could be the pickup clearance as mentioned. Also could be that somehow the distributor didn't engage the oil pump when reinstalled. Not sure how that could happen without being apparent. I have Fords, Mopars and my Corvette and I get some of the distrbutor details confused from memory but I think a nylon collar is used that can fail. My 427 has an aftermarket steel one as I remember. I think you are going to have to pull the pan again to investigate but first I would check the distributor drive as it's easier.
Oil
Is it possible that the oil pickup fell off? It takes some time to fill the filter to get a reading on the gauge. Since you are using a canister type filter, it is difficult to fully prime the oil filter before you install. You could also remove the distributer and directly prime the oil pump. Remove a valve cover to see if oil is coming up through the push rods. Sounds like the pickup fell off or is blocked by a baffle. Jerry
The distributor is something I thought about that's why I mentioned it the post but I don't think you can install it and not have it engage, I know I did have to walk it around a bit as described by Lars to get the pump to engage with the shaft so I think it is good but will verify it. As far as priming the filter canister, I did not do it, I did not even think to do it,,,, could it be that I have not let it run enough ? Would that still not show any pressure at all ? As far as the baffles are concerned I don't see anyway that it could block the entire pick up, if there was an interference it would be on the end of the pick up that is already blocked not the open end.
Thanks for the ideas so far !
Received 6,521 Likes
C2 of Year Finalist (track prepared) 2019
Before you bolted the new oil filter on, did you fill it with oil? If you did not, it will take an unnerving amount of time for the oil pressure to come up. The problem could be as simple as this.
However....... if it was my engine, I'd pull the distributor and spin the pump with a drill motor and a priming tool to ensure that it is possible to develop pressure. I'd do this before I even thought about starting the engine again.
Good luck,
Jim
Good luck,
Jim
Good luck,
Jim
Good luck,
Jim
I think at this point I will pull the distributor and prime the pump, that will let me verify the gauge, fill the canister and make sure the oil pump and rod are still good to go.
Thanks guys !
Thanks guys !
Received 2,126 Likes
Just for future reference. The distributor cannot seat in the block without it mating to the pump drive (male/female union) intermediate shaft. That shaft is held to the pump shaft (male/female union) by a collar, some plastic, some metal, the metal one is preferred. I agree about filling the oil filter canister first. Dennis
Jim, do you have hydraulic lifters? If you do and you really do have NO oil pressure, the engine will definitely let you know. The valves will be clattering like bolts in an old tin can.
If you do have hydraulic lifters and they are not clattering, the problem is very likely in the gauge. A problem that many owners of older C3's have encountered. Flush the line to the gauge and the gauge itself with a can of "brake-clean" and it will very likely free up the goop that is not allowing the gauge to respond to the pressure from the oil pump.
Good luck... GUSTO
Good luck... GUSTO
I did not let it run for long as it was late and I did not have time to trouble shoot it but the lifters were still pumped up and not clattering. I do believe the distributor / pump connection is good, it has to be or it won't go together, the gauge was fine before the work was done so it seems that I just did not give it time to work up pressure. I will pull the distributor and prime the pump with a V/C off and go from there. From now on I know to fill the canister, looking back that should have been a no brainer, but here I am.....
I use a speed handle to prime the oil pump, I like being able to feel the oil start to circulate, it is easy to hit 40 psi with a speed handle rotated by hand. Once you have pressure in the system give it 30 seconds of turning and your good to go.
I tape the extension and socket to the speed handle so there is no chance of dropping it in the engine. ( That would make for a bad day )
Probably should fill the filter first, as I've often wondered if damage could occur, but it's kind of a PITA when you're laying on your back and don't have a lift.
I never pre-filled an oil filter until I got my split window coupe - no good reason just never did it. I do it now but again, not for any good reason as I'm not convinced its absolutely needed.
And you can't on some cars as the filters are upside down; even on Ferrari's...
Good point. The filters on my riding mower and Harley are horizontal.
2018 C2 of Year Winner
Imagine the racket that would make waiting for pressure!!!!!
