1 x 4 Air/Cleaner Base
Can anyone post a picture of the proper orientation of the air cleaner base for a 4BL Carter. There are a few bumps in the base and I have no clue the proper position of the bumps.
Thanks,
Bud
Thanks,
Bud
I have a 2x4 but I think the large bump is to clear the bakelite, black choke housing...
Received 1,857 Likes
I assumed in the context of the "1x4" title of his post that it was a WCFB.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Those "bumps" fit inside the rim of the (passenger side) carb on a WCFB. You can't really put it on wrong if it's the right base.
...does the picture show the corresponding mounting / positioning (large bump over choke housing)?
A correct base also has a "tang" that fits inside the circumference of the carb and makes it simple to get it right. AFB has a different length tang than a WCFB, and both of those are single 4-barrels. (1X4)
Kerrmudgeon (02-07-2016)
A small mark with a sharpie under the wing nut is a quick way to re orient the air cleaner when installing.
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Dropped my $500 OEM wingnut on the floor getting this shot!
I believe the large "bump" is needed for clearance when the choke closes and that mechanism pivots.
