Speedo bounce C2
That's a new one - bumps making it bounce. I guess I would suspect the dampening mechanism inside is worn out - not even sure how it works but I believe I remember that cable driven speedos and tachs have means of dampening bouncing movement.
I've seen my speedometer jump if I've gone over a big enough bump fast (hard) enough under acceleration...
At first I was hoping for a really great thread
About the speedo bouncing off of the 160mph pin!
but oh well just a general bounce problem. Therefore I would check the condition of the cable ends and on one of my speedometers, it was doing that and then after one drive I saw the needle fall off and it laid at the bottom of the gauge. Too bad there wasn't a way to epoxy it on prior to it falling off without taking the whole friggin dash apart! Therefore to solve both problems, I had the 200mph thing done!
