Sudden rough idle and huge loss in power
Hi guys,
First post here! I have a '67 vert with a 427 3X2 that recent had its engine and carbs rebuilt. After the rebuild the car ran AMAZING! Smooth idle and revs all the way up the tach. After putting about 1000 mils on it or so we decided to change the break-in oil. While we still had the car on the lift, we also pulled the cluster to fix its bounce speed needle issue. After we thought we got everything fixed, we fired it up. It ran terribly. It didn't want to idle at all until it warmed up a little. It sounded like it was missing a bit from the passenger side pipe though. Any ideas what it could be? We tried changing the points to the Pertronix system with no avail. We went back to a stock replacement to no avail (although I'm not too sure if we got it adjusted correctly). Please let me know if you guys might have any ideas what it might be. Thanks!
So we just changed the plugs, rotor and cap to no avail. We tried messing with the gap of the points a bit but it didn't really seem to help much? Does it mean anything if you step on the throttle too quickly the car will backfire? I hope that's the correct term. Any advice will be greatly appreciated. Thanks!
Check the distributor hold down clamp for tightness. If that starts moving around on you, you'll get all kinds of oddball symptoms...
C2 of Year Finalist (appearance mods) 2019
I went through a time where my car was acting like yours and it turned out to be a broken exhaust valve spring. Tried about a dozen things before I finally pulled a valve cover and saw the problem.
Vacuum
Put a vacuum guage on the intake manifold. Sounds like you knocked off a vacuum line. If not, the vacuum reading will give you a quick look at the valves without pulling anything off. Jerry
C2 of Year Finalist (performance mods) 2019
I've had a loose rocker and a bent valve cause this, but your timing makes me think that the problem is external to the engine. Loose distributor, wire, vacuum hose, etc. since you were not doing much. Above tests will tell you a lot, as well as basic tests of pulling one spark plug wire at a time to see if that makes any difference before compression testing.
As this is an old Corvette, check the electrical system for floating grounds or a new short somewhere...
Here's a question for the experts. Wouldn't a bad power valve do this? steve
Recently i adjusted the carb on my L72, during a very cool/dry day...Soon after the weather turned super hot/humid and my car started running much like yours...Have you been tweaking your carbs any lately?
I still haven't seen where he's checked the dizzy hold down clamp...
