Several Issues I could use advice on
My 1967 BB started having some issues.
1. right headlight door does not open completely. It is hitting the stop. How do I adjust it?
2. Ammeter gauge stopped working. Turn several items on and it does not move.
3. Temp gauge initially goes to normal temp and than slowly drifts all the way to the right and pins itself. I checked temperature with an IR gun and it is normal. Is this most likely ther gauge or sending unit?
Thanks in advance.
Thanks in advance.
Received 1,857 Likes
Thanks in advance.
Thanks in advance.
2. Chances are you have an open circuit inside the fuse block inboard connector for the black and for the black/white sense wire.
3. Gauge Test - with the key "on", remove the green wire from the sending unit terminal - the gauge should peg to full cold. Then touch the wire to an engine ground, and the gauge should peg to full hot. If the gauge tests like this, the sending unit has gone bad.
1. Adjust the bolt at the "open" side of the Y-stop.
