electrical low lights driver side
2018 C1 of Year Finalist
Both the driver side front headlights and rear tail lights are dimmer than the passenger side.
Also, the radio does not work when I have the headlights on. What should I look for? I added a ground to the rear harness to the body on the passenger rear side.
I am running a generator.
You're still losing a ground somewhere. Those are classic symptoms. Could be corroded connection or bulb socket issue, but definitely losing a ground in the circuit.
