WCFB 2x4 Dual Quad Carb Problem
58 Ballst Resistor
Hi All!
Took out pointless distributor & aftermarket coil. Putting back dual points distributor & original coil. I noticed tabs on ballast resistor loose, not the screws to attach the wires.
There is a spiral wires behind the ballast resistor and it moves with the screw tabs, so is tabs suppose to be loose?
Thanks,
Eric
58 spark plug life have been getting shorter and shorter life. 3-or-4 drives and it starts to foul, bad hesitation, rough running from stop light. It has Holley fuel pump.
Got WCFB 2x4 freshly rebuilt, so put 1/4 cup or more gas down carbs to dry start, since fuel pump and lines was dry from removing carbs for rebuild. Then gas started poring out the bottom of Carbs onto the intake manifold.
IS THIS HOW IT'S SUPPOSE TO BE?
2nd problem: because the fresh rebuilt fuel pump failed to bring gas up to carbs, I put back old Holley fuel pump. When test driving same problem as before I had the Carbs restored.
IS THIS PROBLEM CAUSED BY THE HOLLEY FUEL PUMP BECAUSE IT HAS A COUPLE POUNDS HIGHER FUEL PRESSURE?
I think I've got the dual carbs fuel mixture set OK and distributor advanced around 12 degrees (but don't know if the damper pulley has slipped on the crank, giving a false advance reading)
Thank you,
Eric
Thanks,
Eric
Thank you,
Eric
There are good rebuild and then not-so-good rebuilds.
Gas shouldn't have leaked on to the intake manifold if you were just adding enough to prime the carb. If you drowned it then gas might well have run out the throttle shafts. It wasn't necessary in the first place. A decent fuel pump will fill the small bowls in those early Carters in about 3 seconds.
Anyway just what is the fuel pressure measurement ? The WCFBs can indeed be sensitive to excessive fuel pressure. If the old fuel pump was causing the problem before then you just re-introduced the problem by installing it back on the car.
I'm guessing fuel pump is 6 or 7 pounds. But car did run OK in prior years, had Holley fuel pump on car over 10-years.
I wouldn't try to guess at the pressure. Buy or use one you already have, but get a vacuum gauge on the pump (they also measure fuel pressure)....and get an exact measurement. WCFB float levels are very sensitive as well. 7lbs of fuel pressure is approaching the upper limit on what these carbs can handle...
58 coil & ballast resistor, as updated
Hi All!
Thanks,
Eric
Thank you,
Eric
Thanks,
Eric
Thank you,
Eric
