lost head room with new foam?
Going to have my seats recovered this winter so I stopped by a highly recommended upholstery shop today to get a game plan together.
During our discussion I pointed out that I'm concerned that when new padding is installed, I plan on using AK vinyl covers and padding unless you guys convince me otherwise, that I'll lose a lot of headroom in my '66 coupe (I currently have about 2" from top of head to headliner now) with the new padding.
When I asked him about this I couldn't really get a definitive answer except that yes, I will sit a bit higher but that's about all he could/would say.
If I use new foam BUT don't replace the springs would that help? I mentioned removing/slicing a slab off the bottom pad but he didn't seem to like that idea.
Does anyone have suggestions/solutions to my quandary?
Gary
Gary
Therefore
You have a reason to put on some extra weight now to better compress the thick foam!
OK sorry, upholstery shops are a pain in the Rear! You would be better to source your own foam from a Corvette outfit and then find a shop that will not whine and throw trantrums!
Gary,
Have you talked to Mr. Stitch (www.mrstitch.com) in San Mateo? It's about a two-hour drive from Wilton. I have no personal experience with them yet, but from their web site, you can bring your own materials, and they do custom work. Maybe they can address your concern. If they ARE the shop you've visited, I'm out of ideas.
Yep, you will lose some headroom and sit higher with new foam. The "buns" on my seats are 25 years old now (restored in 1990) and still fresh and high compared to some other well worn in midyear seats I have sat on. The '65 has only been driven about 5,000 miles in those years so they are still fresh in that sense. I am 6'4" and just clear the headliner still though.
Thanks for the info guys.
TC: Not gonna gain weight, I'm a svelte 6'1" 200 pounder.
SI67: Thanks for the info, I'll keep him in mind.
gilbybarr: I put on close to 5000 miles in one year and am 3" shorter so that's encouraging.
Scott: Now that's what I want to hear! What about the question of using my current original springs? Yea or nay.
Anything anyone else can add will be appreciated.
Gary
Gary
Maybe I have an unusual case (a GOOD upholstery guy), but I have a local upholstery guru that does my work and he always recommends against the pre-fab foam in these cars for that reason. he builds up varying densities for different areas of the seat. this is the guy that did my 62, and I'm 6'2" 220 yet fit comfortably in it. the seat base looks tight, with no-one sitting on it, but the softer foam lets me settle right in like a cat in the lap. on my 62 he used the original springs, but replaced some spring clips here and there.
Russ
Russ
Gary
Gary
Speak to Al Knock's about that. I know they have come up with some specially designed seats for tall people. They may be able to supply you with a thinner version of the foam or even do your seats for you to your specs. They make all their own stuff and were very accommodating when I was working on the 64 and needed some individual pieces . Pilot Dan
ps: I just checked and I see they are going to be in Pomona CA on Dec. 6, 7. Don't know how far you are, but you may be able to arrange for a show install and save shipping.
Gary,
Gary
Not really appropriate to your issue but in case others are having issues with new foam. I faced the same issue and because of a winter of no driving, I put (2) 50 pound bags of sand on the seat during the non-driving season and come the following spring the seats were more comfortable.
Rick
Rick
Thanks Rick, I'll have to remember that trick, just on the in case.
Gary
Gary
Al Knoch did my C1 seats at the NCRS meet in Kissimmee, FL a few years back -- it took them all day for both seats but I bolted them right in and drove the car home afterwards. It was interesting to watch their tech working away at the seats and made me glad I didn't attempt it myself. I scheduled about a month before the show...
