lug bolt removal 57 rear axle
I tried a search but did not get anything useful.
How do I remove the lug bolts from the rear axel? I have one that is broken flush and will probably have to drill. But I have another that is stripped, and beating on it while on the car is getting scary 'cause it is not moving much! 1/16, or maybe even only a 32nd. I've used a full size ball peen hammer. The videos I've seen on the tube show a single or 2-3 whacks and the studs on newer 'vettes seem to pop right out.
Do I get a bigger hammer? Or do I have to take out the axle and have a shop press these out? I don't want to damage the axle or the diff. due to slamming away w/o any hope of getting these out.
Thanks,
Dennis
Thanks,
Dennis
Thanks,
Dennis
Thanks,
Dennis
Don
Received 1,843 Likes
Pull the brake drum and look at the back side. Someone could have tack welded them in place.
Otherwise, man up and wail on it. You won't hurt anything.
Any suggestions? Not about football. Thanks,
Dennis
Received 6,943 Likes
2015 C2 of Year Finalist
A long punch and keep smacking it
Oh we've manned up on the 3 that were not broken. Ten whacks with a 4 lb. hammer and out. My problem is the one that is broken and I can't get enough force on it! It's flush with the axle flange. The only thing I can think of now is to drill it halfway and put a drift in the hole and beat the H out of it like Alabama is doing to my AGGIES right now!!!
Dennis
Dennis
No, not offhand. I guess I don't understand why your studs would be any tighter than normal?
air hammer, or air chisel, thread on a lug nut some to help contain it. If that doesnt work youll be pulling the axle and heading off to the machine shop, may as well do both sides
I will be the naysayer.
Many moons ago I learned (the hard way) not to beat on wheel bearings. Had a vehicle we were having painted at a friend's shop, and I had forgotten to tell him where the lug nut lock key was "hidden". Rather than call me, he just beat a socket over the locking lug nuts.....
Within a couple hundred miles, front bearings on both sides ( these were tapered roller bearings, which have more surface area than most weaker C1 wheel ball bearings) were making "noises". Upon removal, I could clearly see the evenly spaced indentations on the bearings from severe side impact while stationary. Never did see a problem with the rears, so perhaps those were "stronger".
The term for this condition is "Brinelling".
http://en.wikipedia.org/wiki/Brinelling
Plasticman
Plasticman
Put a slide hammer on the rear axle and beat on it until the axle comes out. Then put it in a press to push the stud out.
Use caution as you'll be beating against the bearings when you use the axle puller. Of course, if you use too much caution, you won't get the axle out. I think the original rear bearings were ball bearings if I remember right.
