BB Oil Pressure
BB Oil Pressure
I changed my oil yesterday in my 396. I changed the filter last year so just changed the oil with Mobil One High Mileage 10-30 Full synthetic. I put in 4 quarts looked a little low on the dip stick, but clear oil it was hard to see so I put in a few more ounces. Started it up let warm up and the oil gauge was at idle 60 and took it for a ride at acceleration it was at pegged at 80. Are those two reading OK? Just dont wan't to over fill. Thanks,Bill
Received 2,130 Likes
2015 C2 of the Year Finalist
Oil pressure is independent of oil level, unless of course you get so low that the pump pickup cannot pick up, in which case you would have no oil pressure.
Oil pressure is primarily a function of bearing clearances (engine health), oil viscosity, RPM and temperature.
My 396 running 10-40 will approach 80 pounds on a cold start and level off at operating temperature.
If you ran it low a quart or with an extra quart in it would not affect oil pressure.
Dan
If you overfill the pan too much you can aerate the oil from the crank. The time it happened to me I was running on the highway and noticed the oil pressure fluctuating. I pretty much knew what I had done so I drained a little out and everything was normal. Each engine series will be different but it would probably take close to a quart too much to start causing a problem in most cases. With 10W-30 my gage is pretty much pegged on a cold start and runs between about 40 and 70 hot from idle to acceleration.
