Another brake bleeding question 66
Hello, I installed a 67 dual reservoir with booster in my 66 manual single reservoir. I bench bled the MC with the bleeder kit and got all the air out prior to hooking lines up to distribution block and front/rear lines. I did not open a bleeder screw yet. I did push on the pedal. I could see the MC when I did this and a large amount of air bubbled out of the forward reservoir. Did I reintroduce air into the MC or do I have a bad O ring in MC or other problem. Thank you,
Al
Al
Received 1,859 Likes
Al
Al
