Did the J65 brakes come with power boosters?
Or were they non-power?
My '64 has a 1967 master cylinder (double/proportional) with booster as it was slalom raced in the 70's and J65 drum brake cylinders (I have a 1964 master cylinder with booster on the side) and wanted to correct my set up, but not sure if there are any issues with the metallic drum brake shoes (J65) on my car. I could either rebuild the '67 master cylinder, which I think is the better MC, or correct the set up. The original brake pad shows non-power. But since I have the '64 MC with booster, I kinda want to install it that way. Don't know if it's correct though.
And yes, I know the '67 MC shouldn't fit because of the hood structure, but that past owner in the 70's cut out a notch that I'm either going to fix, or leave.
Received 1,858 Likes
The '67 master cylinder (if it's for a Corvette) doesn't have residual pressure valves, which are a necessity with drum brakes; does it have separate external RPV's? The '64 master cylinder has an internal RPV.
The J65 metallic brake option included the J50 power booster in 1964 (it didn't in '63), so if you want a correct installation, it should have the booster.
I'll confirm whether Corvette after I get home from work.
The RPV in the '64 master cylinder is internal - see page 5-2 in the '64 Corvette Shop Manual; it's the last thing you remove and the first thing you install when you rebuild the master cylinder.
I'll most likely rebuild and reinstall the OEM '64 MC with booster PB I have on the work bench, but here's what's on it now. I'll replace all the lines with steel during the MC rebuild.
Think I'll rebuild the '67? MC in the future; it's a part of my car's history. Nothing anyone would know about, but talking the owner who slalomed it gave it personal value to me.
The '67? MC that's on it right now is 5455509 has been there since the 1970's, according to the owner at the time.
The '67? master cylinder (if it's for a Corvette) doesn't have residual pressure valves, which are a necessity with drum brakes; does it have separate external RPV's? The '64 master cylinder has an internal RPV.
