Best sealer for SB valve cover gaskets
Does anyone have a favorite sealer for their valve cover gaskets?
I'm putting on a new pair of valve covers, and only want to do this
once, rubber or cork?
Boyan
done right no leaks and you can remove them easily if necessary in the future....adjusting valves or whatever
Received 6,513 Likes
C2 of Year Finalist (track prepared) 2019
Everyone has their favorite sealer and mine is Permatex Right Stuff. An amazing product..... you don't have to wait for it to set before you can return your vehicle to service. Too, it comes in an aerosol can so it's easy to apply a uniform bead.
I generally agree with Boyan's technique: glue the (cork) gasket to the valve cover and use nothing between gasket and head. If you have the time to let Right Stuff dry however, (remember, this is optional), you can also smear some on the gasket surface which contacts the head.
Jim
Jim
Many don't realize valve cover leaks occur over the top of the gasket between the valve cover lip and gasket ... most good sealants work and I use Ultra-Gray RTV just because I had it around. NOTHING between the gasket and head...consider some PAM cooking spray or a little wheel bearing grease along the ridge on the head where the gasket seals. I do this and can R&R my valve covers a bunch of times to adjust solid lifters with no leaks. I also use the 7/32" thicker FelPro cork gaskets...
I think the thicker gaskets allows you to get a little more life out of each set as you tighten them down after removal you still have some cushion left over time...
Snug up those bolts one more time after a couple of hundred miles...
Just invest in a pair of gaskets with a steel liner, such as Moroso Perma-seal. You can use them over and over and over and there is no need for any glue or gook
