61 brake lock
Cruising
61 brake lock
So I have been picking away at my restarted 61 project. I got it running ok. I was able to free up the flywheel/pressure plate lock. But the brakes are driving me nuts.
100% new brakes back in 1999 and never driven. left front bleeder had a drip and after nearly 2 yrs in body shop.....all fluid drained out.
I filled the master (did not bench bleed ) and proceeded to bleed at the wheel cylinders starting with rear.....but nothing would come out....eventually I moved to front and was able to bleed as normal...and got a normal solid pedal........go back to rears and still nothing comes out
....with rear bleeders open the pedal is still normal fell and wont go to the floor.
Any ideas???
Any ideas???
Sure sounds like the line running to the rears is plugged. Seems unlikely that both rear bleeders are plugged, but first thing I'd try would be to completely remove the rear bleeders and see if you can get any fluid to move. Next would be to disconnect the line where it splits at the rear of the car and work forward as needed.
Hank
Hank
Plugged rubber line
Replace the rubber line to the rear axle. This runs from the steel line down the side of the frame to the axle steel lines. Mine was plugged and this cleared the problem.
Ray
Ray
Cruising
I removed bleeders and nothing came out. I then tried a power bleeder I borrowed. Going to remove the rubber line today, Thanks
Had to drive the car from down the street (100 yds.) to its home in my new garage yesterday. I used the e-brake for the most part to get it here. First ride in 14+ yrs.
2021 C2 of the Year Finalist - Unmodified
C2 of Year Finalist (stock) 2019
2016 C2 of Year Finalist
All three rubber lines should be replaced if they have never been. They can be very restrictive with age and swelling. Good time to flush the whole system with denatured alcohol, blow all the lines clear, and replace old fluid with DOT-5. I have it in both of my cars now 4-7 years and no problems.
Replace ALL the rubber lines - they can deteriorate from the inside out and look fine and endanger your life. A few bucks and a few minutes wrenching isn't worth getting hurt...
Combination of fluid, moisture, and flexing (from front wheels turning) and expansion/contraction (from brakes being applied) takes its toll. If they are 14 years old I wouldn't even think about it - replace them all and be assured of your safety.
Cruising
So I finally had time to pull the rear flex line off. It is plugged up. When I press on the pedal it goes to floor now.
To be clear to others who may find this topic helpful.....these lines had Zero road miles on them. soon after they were installed the project was put on hold. They were installed in 1999 and still look brand new.
I wonder what happens that they plug up?
Ordered 3 new ones and hope this helps someone down the road.
