new lift installed!
Moderator
I just installed the Bendpak narrow extra high 7,000 pound unit. I did order the drip trays and aluminum ramps per forum recommendations. The first week needed to jack up the front end of the 61 and wished I had ordered the jack option. How happy are you with the jacks?
Salesman said it would take two guys six hours to install. It took three hillbilly's 30 man hours to install. Counts redoing the cables once.
Ceiling in the far bay is cathedral-- haven't measured it but over 20'. Also went with low profile rails that hug the wall and don't interfere with the lift-- lets me get the lift high enough to park the vette underneath WITH the hood open.
That will work. I had the exact same height. raised the door track as high as I could get them. I have an '84 and a 67 convertible. They just make it. Both cars are about 51" high. Count the height of the ramps. About 4". You have to leave enough room to raise the upper car out of its locks, so that you can then bring it down. Also line the ramps that are above the car on the floor with a/c pipe insulation, so that you don't accidently knock yourself out as you get out. Speaking from experience !!. The insulation is foam and has a slit in it. It slides on and stays on.
Slightly O/T but has anybody come up with a combo using the jack tray and bottle jacks (or anything else) that is really effective ? This image is off a popular tool vendor web site.....I'm not feeling good about lifting the car with that set up at all. As stated above I did one session with a similar setup and it was damn scary
Otherwise that tray is pretty much useless except for holding tools occasionally.
Moderator
The benefit of the jack tray is that it jacks up both sides at exactly the same time and rate, so you don't have to worry about imbalance. Well worth the piece of mind, in my opinion.
Received 1,919 Likes
Nice setup, and that Wildcat is the shiznit.
C2 of Year Finalist (appearance mods) 2019
Someone mentioned the cable going slack and the dangers of that. I made some changes
to my lift to prevent the cables from coming off no matter how slack the cable gets.
I would have thought by now the companies that make these lifts would fix this problem.
Here you can see how loose the cables get when released.
I used a bolt with a hole drilled through for a cotter pin. I left enough room for the cable
to not touch anything, but there is not enough room for it to come off.
I bent flat bar into a "Z" shape for this spot. I used 2 bolts to secure it so that it wouldn't spin.
This is just a flat bar bent at a 90º angle with the original locking collar welded on to it.
Replace the locking collar with the new keeper you just made.
This is a better look at it.
Nice, Come vacation this winter in Florida and do mine.
Yes, my tech came out to fix my slack problem and blithely explained that the pulleys had no 'keepers' on them. Why not ? To save $50 on metal and a little extra assembly ?
Pretty silly IMO.
They use massive overkill on the cable (mine is 14,000 lb strength), and double mechanical locks, but don't put keepers on the pulleys.
Pretty silly IMO.
Moderator
Now added an 80 gallon compressor--- now just need to get some air tools :-)
And to head off the comments, Yes I did leave it on the skid -- I don't want to bolt it down, and it tends to walk if it's sitting on bare concrete. I'm going to box out the skid so it looks neater though.
Received 1,857 Likes
I mounted mine on body mounts on concrete - hasn't moved a bit in 14 years.
#34
Cruise-In III Veteran
KCJohn,
Great add on safety features to your lift!! Something I should consider but, frankly, I REALLY look over my lift before and after use. Regularly grease the inside columns as well as the pulleys all around. My unit is 14 years old. Very reliable and trouble free.
Awhile back there was a mishap with one of these lifts. Think it was a forum member in the C3 section. Apparently the pulley unscrewed from its position causing the cables to spin off and causing the car on top to fall/slide off.
The fix for this pulley unscrewing was to provide a section of bar stock and hardware with instructions to drill holes for the fasteners provided. When installed, the bar stock prevented any backing out of the bolts that secured the pulleys.
Here's a pic of my install on this back then
Jim
In God We Trust!
Jim
In God We Trust!
#35
4-post cable snap
The front passenger's side cable just snapped on my Eagle 9,000 lb lift. (As I was lifting the car) Three saftety locks held saving my 59. I'm convinced I lowered the lift too low releasing the cable from it's main pully. I will install safety bolts as suggested. Thanks 59 navy
#36
KCJohn,
Jim
In God We Trust!
Jim
In God We Trust!
#38
https://www.corvetteforum.com/forums...-air-jack.html
#39
I have been looking for an affordable jack solution for some time for my Bendpal HD9. I saw this rolling bridge tray and air jack at Mecum in Kissimmee from Advantage Lifts. Very nice people to deal with and they have quality products.
It has a large recess in the tray which the Bendpak tray lacks.
Rolling Tray costs $150, Air Jack $299
How about air bag jacks...see John Z's post in this thread link...
