Question: can '65 disc brake T.A. Assemblies be converted to drum brakes
Former Vendor
So,
I have a set of '65 disc brake trailing arm assemblies that I'd like to convert to drum brakes for a '63 Vette.
Doable?
Doable?
Trailing arms
The trailing arms are different. The disk brake cars have a shelf for bumpstop. 63 spindles are different...as are other parts
I don't think it would be easy to do correctly.
Boyan
Boyan
https://www.corvetteforum.com/forums...rear-susp.html
Former Vendor
No, neighbor has an early '63 that need bearings and likely one spindle.
I have a set of disc TA's from a '65 and needed to know if I could swap out his drum brake components onto the '65 units.
G.
