1962 distributor differences
I am having a hard time finding a reasonably priced 1110984 (250hp) distributor. What are the differences between the 1110984 and a 1110985 tach drive distributor? It seems like the 0985s are plentiful...
I want it to look correct on the outside, but plan to replace the points with electronics on the inside.
Other questions:
1. Does the 0185 have the oil filler or was this specific to 0184?
2. If it is a single point, tach drive with vacuum advance, can this be anything other than a 0184?
Thanks for helping me understand
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
ALL 62 distributors were tach drive.
The 250 and 300hp distributors were SINGLE point with a vacuum advance.
The distributor for the 340hp engine (solid lifter with a carb) was dual point and NO vac adv.
The FI dist was also dual point and NO vac adv.
ANY 63 74 distributor with vac adv will work for your engine. ALTHOUGH not totally correct, they can be setup to work just fine. The primary differences between 63-74 vac adv, single point distributors will be the mechanical weight advance setting and the vac adv canister. BOTH of these features can easily be tailored to suit your engine.
Yes, the REALLY, REALLY knowledgeable judges/distributor gurus can spot the difference between the really early tach drive/vac adv distributors and the later versions. But MOST people will not know the difference between a 62 vac adv/tach drive and a 74 version. When installed in the engine, they look virtually identical. The vac adv can is in the same position, the tach drive is in the same position and they all use the same single door dist cap.
I VERY SERIOUSLY doubt that there are 3 people on this forum that can describe the minute differences between a 62 and 74 tach drive dist.
62 984 tach drive distributors were the only tach-drive ones to have an oiler on the side of the body, and that oiler was not a tube, it was only a spring-loaded GITS type cap. Nearly impossible to actually oil! It was used on both 250 and 300 hp 62's.
Can someone confirm this is a 1110984 (from above description it is). To clarify that point, I think the 1110984 is the only one with GITS cap, Tach drive and vacuum advance. The 1110985 has the first two, but not the vacuum advance; also is dual points.
I can't absolutely say that it is, but it looks exactly like the 984s that I have been familiar with for years. The upside down gear on the bottom concerns me, though.
I think the 54W football cam is correct for a 984. What is the vacuum can number? The cross gear casting is old school.....do you have the original al distributor band?
No band. I just bought this one and yet to receive it. I will update this post with the vacuum can number when I get it.
