Take Out Powerglide Put In 4 Speed
If you consider coming all the way over here then Dewey Hendricks is a first-rate midyear guy but stays pretty busy.
Do not use AntiVenom in Seffner, FL over your way
A parts list John Z listed a while back
Parts needed for 4 speed conversion
Flywheel & special bolts
Pilot bushing
Clutch Pressure Plate & Disc & special bolts
Bellhousing, bolts & Fork Stud
Throwout bearing & moly lube
Clutch fork & boot
Transmission & bolts
Shifter & linkage & bolts
Speedo cable & clips & 2-hole grommet
Manual console plate & shift pattern plate
Shift boot & retainer plate
Brake & clutch pedals & pads, bushings & pushrod bracket & bolts
Clutch pedal pushrod, spacer & retainer clip
Clutch cross shaft assembly & engine-side stud
Pedal pushrod swivel & jam nuts
Pedal pushrod boot & screws
Return spring & retainer at dash
Lower fork pushrod, hardware & anti-rattle springs
Backup light switch, bracket & wiring
Pilot bushing
Clutch fork & boot
Nice list. Thanks John Z and Outlaw67. It is a little scary though. I was hoping by using a rebuilt trans and used shifter and maybe some other used parts that I could get the swap done for $2,500 or so. With someone who knows what they are doing making it happen. I don't know?
It should be a relatively easy job , give Willcox or similar a call if you cant find a good used one local .
http://willcoxcorvette.com/advanced_...ccd1ec9e577cc3
and buy a workshop manual if you don't already have one
Received 1,857 Likes
This is good news. Now all I need to do is find a good M20 Trans, buy a clutch, bell housing, shifter, a bunch of other parts and find some one to do the work. What about the carburetor. The AFB I have is for an automatic and has the lever for the kick down. Can I use this carb or put on a different lever or what?
