AF ratio meter and Vac gauge
Received 1,240 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
What are the best (for the money, not necessarily the most expensive) devices for measuring air to fuel ratio and engine vacuum ?
To me the most accurate way to check air/fuel mixture is with a 5-gas exhaust gas analyzer because it allow you to read the mis-fire rate (HC), engine efficiency (co2), air/fuel mixture (CO), exhaust dilution (o2) and if the spark timing is too advanced for the octane of the gasoline (NOx). Any smog station can give you a print out of the readings for $30 or $40, a wide-band "oxygen" sensor based air/fuel meter is a great tool but the accuracy of the readings can be effected by engine misfire or any exhaust leaks. I use a portable 5-gas analyzer plus we have both Innovate and FAST wide-band sensor based air/fuel meters that we use for tuning. If you are interested the following link is to a article on air/fuel mixture tuning
http://www.enginebuildermag.com/2008...fuel-equation/
Any brand vacuum gauge is fine depending on what you are doing or if you have money to spend Bosch has a engine analyzer (MTS5200) that can allow you to look at the vacuum signal of each cylinder in real time if you are looking for an advanced diagnostic tool.
I hope this helps Henry @ oles carb
Have any of you used this one, and if so, were you satisfied with it?
http://www.ebay.com/itm/Edelbrock-6593-Electrical-Air-Fuel-Ratio-Monitors-EDE6593-/360831709538?pt=Race_Car_Parts&hash=item54033ef162&vxp=mtr
[QUOTE=Dr L-88;1588170670]Have any of you used this one, and if so, were you satisfied with it?
No, I have not used the edelbrock unit but it uses a narrow band "oxygen" sensor which is only accurate at 14.7/1 A/F mixture. Innovate offers a wide band unit http://www.summitracing.com/parts/inn-3802/overview/ that uses a wide band sensor that is a lot more accurate as long as the misfire rate is low and no exhaust leaks.
I'm well before the tuner / ricer generation.......................but this looks pretty interesting.
[QUOTE=Dr L-88;1588170993]I'm well before the tuner / ricer generation.......................but this looks pretty interesting.
I don't understand the before the tuner / richer generation reference but as long as the exhaust sample reference is un-diluted (no leaks) and the misfire rate is low the a/f mixture readings are dead on.
Henry @ oles carb
Henry @ oles carb
I have an Innovate which I have used for some years on my 61. It is easy to use and responsive. I suggest weld pungs in each exhaust pipe and switch the O2 sensor for reading in each exhaust.
I just run the cable thru the cowl vent to use while driving on highway.
Joe
Joe
I also have an older Innovate LM1 which I used to tune the Ramjet 350 in my wife's '62. I have had no problems with it. One of the reasons I chose this unit was that it has an analog output which I was able to route into the Ramjet controller so that I could log the engine parameters and the A/F ratio in the same file. This made comparisons of changes much easier.
Charles
Charles
