'63 original power brakes
Got my restored master cylinder and booster back, installed them and bled the brakes twice. Worst part was getting the pedal height correct as factory (which I finally got done). Ran the booster check out procedures in the shop manual and it's all good.
My question is how far should you have to push the pedal down for the brakes to start working? My pedal, at rest, is 4-1/2" off the floor and it seems like I have to push it down a good 2-1/2" (more maybe) before things start to happen....seems awfully close to the floorboard.
I don't have a benchmark to know if that's normal or not. I dimly remember my Dad's Ford LTD '68 demonstrator acting kinda the same. A long push to get the power brakes going. If anybody has a measurement from the bottom of the pedal to the floorboard on a power brake car when the pedal is fully down (with engine running!) it would help.
Thoughts ?
Morley63 - how are your brakes working ?
Thoughts ?
I don't have a benchmark to know if that's normal or not. I dimly remember my Dad's Ford LTD '68 demonstrator acting kinda the same. A long push to get the power brakes going. If anybody has a measurement from the bottom of the pedal to the floorboard on a power brake car when the pedal is fully down it would help.
Thoughts ?
Thoughts ?
Remember, they are NOT power brakes, they are POWER ASSIST, so they will never be fully like power brakes, and they are on drums, so they will not be like disk brakes, entirely different world, even with power assist they are sloppy.
The brakes are junk, if the car wasn't so nice to look at I'd trade for a 67 with disk brakes.
Received 1,857 Likes
I suggest you find a good mechanic to repair your junk brakes before you have a problem.
When the shoes fit the drums the brakes work pretty good.
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
Getting back on topic
Frankie,
For what it's worth, I have the same booster and the same "style" master cylinder on my car and the brakes are applied with less than 1" of pedal travel.
It sounds like you need to make sure the push rod on the front of the booster is within 1/16" of contact with the MC piston. If you set that distance mentioned in the shop manual from the front of the booster case, perhaps someone used the wrong piston when they rebuilt the MC. You might want to use a vernier caliper and check the depth of the MC piston hole to the mounting flange and compare that to the measured distance of the push rod from the MC mounting surface on the booster.
If the brakes applied very quickly before the conversion, you can rule out loose shoes.
Verne
Verne
Frankie,
Verne
Verne
Thoughts ?
Thoughts ?
If the M/C rod clearance checks OK, you might also try backing-up while pumping the brake pedal to try to get the auto adjusters to snug the shoes to the drums.
I re-bled the brakes and got a little more pedal. I think I was "...hollering before I was hit"....as my brother tells me. The M/C to booster push rod was dead nuts on the money.
The floorboard is a little deceptive - the toeboard actually drops off about 1/2 way up....so as you look down from the driver's seat it looks like the pedal is close to the floor when depressed fully.
However, if you pull the floor mat back and kneel down and press the pedal with your hand there is close to 3" under the fully depressed pedal.
I think I was the problem.....a case of 'recto-cranial inversion'...
If you're talking a '63 the boosters are not reproduced and prices for originals will hurt your feelings badly. Forum member "W Guy" has some passenger car boosters for sale on here and you can put the '63 bracket (from Dr. Rebuild) on the back and 99% of folks won't have a clue you did it. Zip now has the '63 power brake master cylinder available in a nice reproduction but without the GM casting number on the bottom (which nobody can see anyway).
This approach will get you power brakes (albeit with a little more work involved) for a fraction of the cost of original stuff.
It turns out there is a spec for '63 power brake pedal height buried in the shop manual. It's 4-5/8" measured from the floor covering to the top of the pedal pad. I readjusted mine which dropped the 'at rest' position down 3/4" and I think that might be the ticket to take up the 'slop' that bothered me with the setup. I'll do a test drive tomorrow to see for sure....
