cluster housing broke
I am getting my odometer and trip meter repaired. After removing the cluster I placed the cluster on the work bench and removed the speedometer. I then began to wipe down the backside of the cluster. Much to my surprise, a piece of the cluster housing broke off. The piece is at the bottom near the headlight switch. Can it be repaired? I really don't want to replace the cluster.
This is a weak spot on these clusters. JB-Weld alone will not hold.
Is it broken in this fashion ? If so, I can share what I did on my '63. However I didn't have the missing piece...so you have a leg up on me...
In your case you would do the same thing but with the broken off piece that you so fortunately have. This fix is rock solid and won't break again.
The finished product.
Your fix will look better than what I have done with the vinyl.
I could have spent more time to smooth out the underside but in a '63 (as shown) the left hand vent cable bracket gets bolted up to where my repair is and the dash steering column escutcheon is also there so that part of the repaired area can't be seen anyway.......
Instead of the vinyl shown in the last pic in my previous post you would insert the broken off piece.
The paint shown in this picture matches the C2 cluster black quite closely. You can dab it on the joint where the missing piece will be attached and just tap it lightly with a fingertip to dull it just a tad and the fix will be undetectable.
Hmmm..... That will certainly just bust off again if you try to use JB-Weld alone. I backed the area up with a piece of steel stock carefully held in place with screws in the standoffs behind the windshield wiper switch. I then covered that with JB-Weld (the ORIGINAL JB-Weld not the JB-Weld QIK stuff). Then, since I didn't have the missing piece I fabricated a fix using some grained vinyl from a C2 dash pad which I embedded in the JB-Weld.
Good luck with it
Sometimes a knee banging in to it is all it takes or, in the case of a '63, somebody man-handling the left hand vent cable can break this piece off
It is the unrestored, original, one-year-only cluster out of my split window - the break was already there when I got the car. The chrome on the gauge face rings and silver on the sides is perfect with no pitting. I just couldn't let this cluster get tossed so I tried fixing it.
I sent pics before the repair to several Corvette instrument cluster restorer types and they said its unrepairable. Now it'll have another 50 years of life. A few hours with some metal, a hammer, and, bloody fingers (I hate sheet metal work)
Before anyone asks the cluster is already sold to a forum member (with gauges included)
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
Frankie did a great job, but let me recommend using 3M panel bond instead. It is by far the strongest two part epoxy/bonding adhesive I have every used. The only downside is that you will need their specific dispenser gun to use it. Panel bond 8115
http://www.summitracing.com/parts/trm-8115/overview/
Cluster
If you are not happy with the repairs, you can usually buy a housing at some of the larger Corvette shows. I have seen housings in bins at the NCRS show in Kissimmee FL. Coming to Florida in January to buy a housing sounds like a great excuse to get out of the cold and drink beer with some friends. Jerry
I still like drinking beer with friends though
Anyway - the whole point being -- if the OP wants to attempt to repair his original cluster (or have somebody do it) its entirely feasible...
One year only
Frankie: I get it with the one year only. I have a 68 and like the 63, many parts are unique to the year and sometimes to a run batch of cars. We really should drink beer and talk about it. Jerry
I wasn't actually asking for my repair to be critiqued...I just offered it up as an example of one way to fix the OP's problem. He's free to turn over rocks for another solution; I'd love to hear what that is when it happens.
Yeah -- that's what I thought when I talked to the cluster/instrument restorer types...they would just tack it back together. They wouldn't touch it. JB-Weld is hardly glue. The side I fixed is as strong as it was from the factory.
Can't believe that you are taking abuse for offering some good advise. Didn't talk to my neighbor yet. I will definitely use your approach for the repair. Hope I can find the right sheet metal. Might try the 3m adhesive.
