Tilt Steering
Fitment wise it is plug and play as it was prototyped from a 63 column. Wiring wise it is not. If you are running a factory style 63 harness the turn signal switch plug-in will have to be modified to fit the FR column's wiring.
it in the car. Good luck, you will enjoy the extra room.
Great, I guess i'll order one. I was at Goodguys in Scottsdale last weekend when I saw their booth. I noticed the wire connector right away and gave the guy a HhMmmm when he said it just plugs right into your stock harness??? Anyway, thanks I don't think there's anything I can't deal with there.
