Recommendations for new 5 spd on matching # '66 BB 425 Coupe
St. Jude Donor '15
On my recently purchased '66, I just discovered it has what appears to be an M-22 trannny from Aug 19, 1970, while it has been in the shop. Housing case casting #(3925661), date code/ratio code stamp (P0H19C), shaft diam size all say M-22, short of opening it up and inspecting the actual gears. Anyway, not original matching tranny like the engine is.
I have upgraded/Borgeson the steering, moded the front/rear suspensions, new centerforce dual clutch, new MSD ignition, rebuilt original Holley 4bbl carb, rebuilt/balanced original drive & halfshafts, and new wheel bearings. I also had Vintage Air put in w/frontrunner system, along with new custom aluminum radiator w/dual fans. So, it obviously won't ever be a trailer queen, judged show car, but a very strong driver. Lots of $$, so why stop now?
All that blah, blah, being said, what brand/model 5 spd tranny would you guys suggest?
I want to keep the original chrome Muncie shifter in the car, as the interior is substantially original/factory correct repro'ed. She still has her original rear end, , a 3.55.
Also, what is the widest brand name rubber I can get for medium/high speed (50-90mph) aggressive handling/performance/safety on K-H repro KO bolt on's (currently holding 205? Coker Goldline radials) inside the original fender/wheel wells & on the road, without rubbing in turns or doing damage to fiberglass at slow street speeds? Fender flares NOT an option!
BTW, I'm real new to the forum. How do I insert a picture of my gal car into my empty Avatar? Wish I had some like Kermudgeon does!
Thanks, for your patience reading this, and your responses.
Randy T.
66TexVette
PS, I have yet to actually drive her, other than 2 test drives before purchase, and the drive from the transport drop off spot to the resto shop, where she has been the last few months. Almost done (for now, if ever?), itching to take her out dancing!
Randy T.
66TexVette
Received 6,942 Likes
2015 C2 of Year Finalist
Why in the world would you ruin a correct car when there are fair more incorrect cars to do. And how do you know you need all that aftermarket add ons to enjoy the car. Without even driving the car. Gladd it's your money.
Randy, more than likely someone has already welcomed you to the Corvette Forum but if not...welcome. I expect you'll be hearing from a number of the members who've made the move to an overdrive manual trans. Post up some pics of your new acquisition when you get the chance and you should be able to find some helpful tips on posting pics and setting up a pic for your avatar in the stickies at the top of the Forum listings.
Mike T - Prescott AZ
LGT 700. It is an all new trans. Not an old trans that has been rebuilt. I have one in my 66. Not cutting required. I love it. You will have to use their shifter but it is an exact copy of the original. I've worked with the manufacturer due to problems created by the specific distributor that I bought it from(no longer in business, BK) and the manufacturer was great to work with. They now have other distributors.
St. Jude Donor '15
I did drive this car on two occasions in two days over a variety of speeds and roads - in town, country, and interstate highway. It's manual steering handled like s**t, to put it nicely, and it's ride was rough, loose, and unpredictable. In fact, it was very dangerous to operate, especially coupled with all that power. Not enjoyable at all.
Everything else on the car was very attractive, especially the extremely strong running, matching # 425 engine. That is one reason I bought it. The other reason is explained below.
Everything that was done to the car can easily be removed and replaced with all the old parts that came with it, which are boxed & waiting by it's side, should a prospective buyer wish to have it in a more original state. I will be glad to dispose of all the offending upgrades elsewhere, especially if I will get a higher price from a purist such as yourself, interested in show awards versus someone wanting a really sweet, powerful, comfortable, and safe ride that still turns heads.
All my "sales" speak is really moot to me, as I am 62 years old now, and have been waiting for this girl ever since I first laid eyes on her twin sister 45 years ago in 1969, as a High School senior looking for his graduation present. Although never consummating my first car love, I never forgot about her over the decades of life. My intent is to dance slowly AND vigorously AND often with her in the few years I have left on this Earth, not to impress others at a show. We have a lot of catching up to do. I will be buried in this car if my heirs do not want it.
I hope this long explanation of mine helps you get your head around my actions, and sufficiently answers your primary question of WHY?
It gives me great pleasure to know that I have made you gladd!
St. Jude Donor '15
Randy
66TexVette
St. Jude Donor '15
St. Jude Donor '15
Randy,
What tire sidewall are you inclined to install? Blackwall, whitewall, gold or red lines? If you are looking for a good radial with a gold or red line, I would suggest Diamond Back Tire, otherwise most other tires can be found at your local big name tire stores. I run Michelin X 215/70/15 redlines on my 67 and love them. Purchased from Diamond Back but they are pricey, I understand they are about $1100 today.
Rick
P.S. Welcome to the CF.
Rick
St. Jude Donor '15
St. Jude Donor '15
Randy,
Rick
Rick
I will check out Diamondback and Michelin X's.
So, 215/70/15's won't rub the wells on slow full turns or bounce off bumps into fiberglass panels? Probably a stupid question since you just recommended them off your '67 to me. Just making sure.
Randy
St. Jude Donor '15
This setup, LGT 700, would do well for a BB 425 with a 3.55 rear end IYHO?
I'll check out LGT tomorrow. It's late, I'm hitting the sack now.
Randy
5 speed
Hi Randy,
Regarding the 5 speed question - I put a RS400 in my 65' L79 and really like it but you would need a RS600 to handle the power of your car.
I have it connected to a 3:55 and found this a good combination all around.
When I was choosing a new tranny' and Rear End, I mapped the RPM vs MPH for each gear from 1000 to 3000 RPM - So basically you get a Saw Tooth chart from 0 MPH to 100 MPH -
Then I did the same for the 5 speed transmissions using this program and it allowed me to improve the low and high end performance
http://www.corral.net/tech/gearcalc.html
Phil
PM your email address and I will send you the excel chart
Phil
2021 C1 of the Year Finalist - Modified
Don't worry about the purists, they do their own thing. Like paying $200 for the correct wing nut for the air cleaner. I'm gladd it's their money ! You are making a good car even better. I'm sure you will enjoy the car and drive it more with the 5spd. I put a TKO 600 in my 64 along with a hot 454, it's WAY better than 327 4spd.
Look into the TKO kits also.
St. Jude Donor '15
Hi Randy,
Phil
Phil
Thank you, Phil, for your response. What company makes the RS 600?
Most of what you just said went over my head, but you what you're talking about, I'm sure. I am admittedly not very well versed in auto mechanics or technicals. Just love to drive 'em!
I will PM you later with my email for your chart, which I will probably need a tutor for. Thanks, again, for your help.
Welcome! Can't wait to see photos! I applaud you for doing exactly what you want with the car you've waited so long for. Keep in mind that some people on the forum can sound derogatory, both intentionally and at times unintentionally, but by and large the group is supremely helpful and a whole lot of fun. The C1/C2 board is a community almost unto itself, I rarely look at any other side of the forum
