compression fitting on oil pressure gage
Hello, I'm putting my restored dash panel back into dash. I can't seem to get the line torqued to get a seal on the oil line. I'm at the point of taking the panel back out and try to get it compressed out of the car. Is it possible that I will need a new oil pressure gauge? My car is a 1966 327/300
Thank you,
Al
Thank you,
Al
Thank you,
Al
Thank you,
Al
Pictures and discussion etc. should be in the archives if you check.
Larry
Oil line fitting
If your oil line fitting does not look like the fitting on this oil line,
You will never get it to seal. Chevrolet used their own design fittings. Like powershift said, they are available from many forum vendors. Make sure you hold the square fitting on the gauge with a wrench when you tighten the hex fitting on the line.
RON
The oil line should be a (copper) plated steel line. The end fitting to the gage is special and not an ordinary compression fitting. I think LICS and Paragon (and probably others) sell this connection.
Larry
Larry
Al
Thank you Ron,
Al
Oil Line
Don't mean to hijack your thread, but I have the copper line that installed 10 years ago. Is there a functional reason I should change to the copper plated steel line?
Randy
Received 1,857 Likes
The copper line can "work-harden" with vibration and eventually fatigue-fracture; that's why GM didn't use it.
Not certain that he heard me.
Larry
I (NCRS) judged a 1966 this weekend that had a poly or nylon small diameter oil line. I told the owner that this was an accident waiting to happen: either oil loss to the engine or a oily mess inside the cabin when it finally breaks.
Larry
Larry
Dave Z
Physio (01-18-2019)
Several years ago, I was working around my oil line and broke the tubing at the fitting to the block. I was in a pinch to get my car back on the road and I found this fitting at my local Napa Auto Parts store. It slightly different from the original but it worked until I could get a new line and fittings from Paragon.
http://www.napaonline.com/Catalog/Ca...0X2_0080518851
Will someone kindly tell me how to get the nut off the oil line at the gauge? It can't be reached with a flare nut wrench - or any other wrench - because of the angle. There isn't enough room to hold the square nut on the gauge while attempting to turn the oil line nut, and try as I might, I can't get the nut to budge with needle-nose ViseGrips.
Anyone know a trick that will work?
Needle nose won't do.
1960 (02-20-2024)
Hope this helps.
Al
While your oil pressure gauge is out being restored .... What do you use to cap the oil line so that you can still start and run your car without squirting your face with oil ?
Ray
Ray
You may have to take off the throttle rod at the firewall and possibly the spark plug/ stainless bracket. This should give you enough room to remove and install fittings. Hope this helps.
Al
1960 (02-20-2024)
Oil line
Thank you,
Al
Thank you,
Al
Just a good point to know. The compression fitting that slides on to the oil line must go at least 1/8th " past the end of the cut. It is not always easy to do this, sometimes you must lightly sand and taper the line so the compression fitting will slide into position. When this fitting is tightened it will compress on the line and seal it. Once used in this manner it cannot be reused. If the oil line is not well seated into the body of the gauge (where it must be sited before the compression fitting is tightened) and the compression fitting does not seal on the oil line well behind (at least 1/8") the cut end, you will either have a loose oil line or a leak. The photos above, so kindly posted by other members, give a clear idea. Unfortunately clearances vary from different manufacturers and some compression fittings do not easily slip over lines. Best...
Thank you,
Al
I looked at the gauge fitting with lights on. I think my question was dumb! The line bottoms out in the bottom of the fitting where it is chamfered / beveled. I can see where rounding the end with sandpaper would let it fit better and more contoured to the bottom of the fitting. I don't know if it will protrude 1/8" from Line fitting.
Thank you,
Al
Does this mean the oil line should be tapered so it enters the hole in the gauge fitting beyond the tapered bottom of the gauge fitting and slightly into the hole. The lightly sanding of the line allows the line to go farther into the hole? Also you said once this is done it can't be remove and reused? So the gauge connection should be done first and then threaded through firewall and block connection done last?
Thank you,
Al
Thank you,
Al
Thank you,
Al
Thank you,
Al
Al, You do want the end of the oil line to protrude just past the compression fitting. When you tighten up the nut the compression fitting will close up tight where it sits on the line.
If the fitting does not slide snugly onto the oil line, then you may have to lightly Emery cloth the oil line to enable the fitting to slide into position. And yes, I would do gauge side first and check for a secure fit before block side. Be sure to install block side compression fitting the same way, once you have tightened these fittings that is where they will stay. If you make a mistake and you have enough line, you can cut it and use new fittings. However, a new cut will make it very difficult to slide on new fittings. Good luck with your project, I would like to know how you do. Best...
1960 (02-20-2024)
