Mystery of green clip mounting holes
Trying to replace rear brake crossover line on 1966 built in Feb 66. I believe it is mounted to the front side of the rear frame crossover member by two " green clips " but have been unable to find any mounting holes for the clip retainers. CF Archives, assembly manual and web search have come up empty as to the actual mounting hole locations. I would GREATLY appreciate your information and any pictures would help. THANK YOU
Cruise-In III Veteran
Tmichaelson,
Realize mines a '65 so take these pics with a grain of salt but think the clips are probably the same.
As Mike Geary said that rear brake line is mounted on the backside of the rear crossmember.
Here's some pics of the line placement and the clips on mine:
Keep in mind, mine ain't green as it's a Not Correctly Restored Stingray.
Regards,
Jim
In God We Trust!
Regards,
Jim
In God We Trust!
Clips
Clips
I don't want to hijack this thread, but I see something that my '67 is
missing. Rick, if you don't mind, what is bolted to the rear of the crossmember between the empty exhaust tubes? My car has the threaded holes, and I've been wondering what belongs there.
Thanks for any info, Gary
Threaded holes
Rick, in your photo, on the upper half of the x-member in the center, are two fasteners. One is below the e-brake cable roller, the other is below the u-joint. My car is a 4 speed as yours is, but mine lacks anything bolted in that position. threaded holes are there, but 'nobody's home'.
Thanks for all responses
