Looking to purchase 66 / 67 C2
I have begun to look for a mid year and have learned a lot by reading this forum. This is my first posting so apologize if mis-stepping here but am considering this one on eBay.
http://www.ebay.com/itm/131358710047
Says it had frame on restoration and has been repainted (both of these make me a bit suspect) but owner says it drives tight. Thoughts?
I do plan to have a professional inspection done (likely spending $300-$400).
Jack
Happy Thanksgiving and welcome to the forum. Here's my take on this car.
1. Although the car as A/C (a big plus) the price is too high for a low HP auto with a color change.
2. I'm always leery of a painted engine stamp pad.
3. Described as having a teak steering wheel, it's not, it's plastic.
4. Aftermarket radio and antenna.
5. Not only does the rear spring look flat and may need to be replaced but whoever installed it didn't even remove the shipping retaining bands.
6.He states he that he has a clear "Texas" title so why does the car have Missouri plates?
I'd be tempted to pass on this one unless he's willing to come down at least 10k!
Gary
Gary
I'd be tempted to pass on this one.
Gary
Gary
Where do you see the shipping bands?
Received 2,126 Likes
Welcome to the CF. Stay in touch and ask any question you like. Very nice looking car with a beautiful interior color. I noticed a couple of things, no big deal. Front sway bar and end link bushings are urethane instead of rubber and the rear spring is a replacement from some source with non stock band wraps. You are doing the right thing having the car checked out. But, will that person be knowledgable of C-2 Vettes, they are unique. Dennis
Gary
Gary
They're located about 6" from the end of the spring. They're those rectangular pieces with the little rubber flaps on the bottom. They're put on at the factory (aftermarket) for shipping then are supposed to be removed once the new spring is installed.
I also noticed that the master cylinder has been replaced which is fine except it wasn't replaced with a stock one. Difference in price? The replacement on the car cost about $200.00, a stock cylinder costs around $900.00.
I believe this is a very late production car and some of those had the new to be '67 design seat belt buckles. Dennis
Received 1,043 Likes
C2 of Year Finalist (appearance mods) 2019
Where can you get an air cp for much less? Even if the engine where wrong a air car is still worth $40,000. You would need to do an inspection on the body and the vin tag they are important more then a few small things being wrong. I believe the seat belts are correct with that vin#. I just looked at another 66 Air cp for about the same money and the body was trash under the nice paint.
Steve
If you are interested in a 66 small block car, there is no reason to rule out 65s. In fact, the 65 is the best year mid year ever made, despite what some will say that 67s are the best.
You might look at the thread entitled corvettes dead in CAN.
The poster there has been trying to sell his 65 coupe, and getting no action at all. Car is supposedly priced to sell. You may catch him at a good time to buy.
Good luck
Good luck
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
Gary
Gary
I can't believe someone painted a Nassau Blue car white. Not that it looks bad in White - I've never seen it done.
I'd put $40K on it.
He's used the pictures from when he bought it, I would guess. That's from a dealer in Missouri. You should call them to get more background.
I'd put $40K on it.
I'd put $40K on it.
That dealer specializes in Vettes, primarily driver quality like this one. Pretty nice guys though. I wouldn't let that stand in the way.
Good luck
Good luck
What makes 1965 the best C2?
As for the original topic, from the photos, the car looks very nice. The interior is in much better shape than the one in my car. The color combination is sharp. I sort of get the motivation of whoever changed the paint color: The contrast is nice.
