Dash Pad
Cruising
Dash Pad
Does anyone have a easy effect way to remove the foam from the back of the new dash pad so the gauges and the corvette piece on passenger side will fit besides 400 sand paper? and do you need to remove any up by the windshield?
You have to tell people what year car you are working on. I happen to know but others do not. I've never removed anything from the back of the pad up close to the windshield and I've never heard of sandpaper to remove the foam backing. A sharp, and I mean SHARP, razor - changed often is what I use.
I'll say again as I did in your previous post - do NOT remove any foam unless you are utterly convinced it has to come off. Its easy to cut more away, putting it back -- not so much...
Cruising
Dash Pad
I use a long pocket knife with a dull tip so it doesn't puncture the vinyl.
I was happy about a year ago when I opened a new AK pad and saw duct tape on the backside of the cluster area padding. The foam came off easily by hand.
However, the next 2 pads I got did not have duct tape there, so I had to revert to the "knife" method.
Also, take note of the foam density just to the left of the left front lower cluster "point". If the foam is very soft, or missing in that area of the wraparound corner there, you will get wrinkles when the cluster is permanently installed. I had to return one to AK because of this, after spending a good amount of time with Al on the phone to diagnose the problem.
Like this.....
Also check the lower left area of the dash insert area for the same issue....like this. I got one in that a prior owner installed, but when I inserted the dash insert, it looked like this....
After much time and rework using batting from my wife's quilting filler scraps, it was better.
Like this.....
Cruising
Dash Pad
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The old production of dash pads always had too much foam in the center area which made fitment hard to do. I used to have 12" de-burring bit for trimming it down a tiny bit at a time, and then test fit trim, test fit, trim test fit...... it was a royal pain in the rear.
The newest CA pads are awesome. You don't have to trim anything, and they fit like a glove. The last two installations we did were a 60 and a 58 and both were the quickest dash pad installation I've ever seen.
