Determining Correct Holley Power Valve?
As you know Holley specifies that the proper power valve number is determined by dividing half the vacuum at idle.
My question is; should this be based on the port where the vacuum advance hose is attached at the base of the carburetor (ported vacuum) or should it be based on the vacuum hose going to the choke pull off which I assume is true manifold vacuum?
Application 1966 L72.
Thank you,
Ralph
Thank you,
Ralph
Received 1,859 Likes
Thank you,
Ralph
Thank you,
Ralph
Follow up question please: Typically what is the vacuum increase that one would expect to see at the choke pull off vs. the ported nipple, is it around 50% or something less??
The holes under the throttle blade see full engine vacuum all the time, this is where the choke pull off and vacuum distributor advance on C2 era cars draw there vacuum from.
Cruising
The ported nipple is a hole drilled into the carburetor throttle body just above the throttle blade. Depending on the throttle blade position at idle (how far the idle screw is turned) that ported hole may see none or only a few inches of vacuum. As the throttle blade is opened, the ported hole is exposed to full engine vacuum.
If its above the throttle plates its ported...below then its full vacuum. Hollley has some excellent youtube videos on power valves and other tuning items. Its also on their web site.
Some later replacement 2818's had a different primary metering block which made that vacuum port a "ported vacuum" source; on originals, it was a full manifold vacuum source.
Cruising
The carb base plate has no vacuum connections, should I remove the single 1/4" pipe plug from the manifold and install a hose barb to use for the vacuum advance? Will that be a benefit for an improved advance curve, or is the ported vacuum better?
I am getting about 56' total advance at present, about 16-18 initial, up to 36' centrifical, and towards 56' total vacuum all in. Is that just a bit to much, should I back the vacuum down a few degrees?
You should put a vac gauge on the nipple as tbarb suggested before you go moving things around to see what you have.
56* total + vac advance is pushing it; however you realize you can't measure that on a car sitting still ? Right ? Vac advance is load based on cruise vacuum not RPM. However, if you have no pinging or "trailer hitching" when driving then its prob fine..
I'm no expert on big blocks, but I don't think they need as much spark advance as smallblocks because the spark plug is more centrally located in the porcupine heads.
If smallblock ideal WOT spark advance is 36-38 BTDC, then BBC is more like 32-34 BTDC, add in about 17 degrees vac advance, and total cruise (that is, if L72 centrifugal is all in at cruise) should be about 49-51 BTDC.
Sure you can!
Yes - that's the way to select an initial parameter for the vac advance can. I just didn't want anybody to think they can measure vac advance on top of 'all-in' initial and mechanical by revving the motor in their garage -- I prob could have phrased the issue more clearly:
https://www.corvetteforum.com/forums...post1582053859
Yes - there was a production fitting for that - Paragon #1361 or #755.
If the engine is free revved (no load, in neutral) the vacuum advance diaphragm is fully deployed.
