64 Alternator 1100669 (10DN) Bad diode
Old 12-10-2014, 11:44 AM
VITIV Coupe
VITIV Coupe's Avatar
Default 64 Alternator 1100669 (10DN) Bad diode
I am still experiencing that dreadful parasitic battery drain. I thought I had it solved, not. After putting the battery charger on the car overnight, I felt the alternator and it was warm, as was the voltage regulator. So after reading numerous post on battery drain, had nothing better to do today so I took the alternator off the car. Ran some test and found that one of my Positive diodes is faulty. The other two were fine. Where can I purchase one and my alternator is 42 amp. Are diodes specific per alternator or can you interchange one from a 37amp-60amp?
Thanks, Leo
Old 12-10-2014, 12:00 PM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
At one time, i could buy a diode kit at NAPA.
You may want to just buy a rebuilt alt and swap out the diode plate and brushes.
The amperage would be determined by the stator.
Doug
Old 12-10-2014, 12:37 PM
Pilot Dan
Pilot Dan's Avatar
Standard Ignition parts sells individual diodes or you can get a complete new kit. Any Canadien auto parts store that carries that parts line can hook you up or you can order one. Pilot Dan
To 64 Alternator 1100669 (10DN) Bad diode
Quick Reply: 64 Alternator 1100669 (10DN) Bad diode
