Lower W/S Stainless
Lower W/S Stainless
Replacing the windsheild on my 65 convertible. There are 11 clips that secure the lower stainless. At some point a previous owner replaced the glass and installed a few more clips with wood screws. Mostly all of the screws where rusted and I had to grid the heads off to remove the clips. The after market clips were installed to far forward leaving a small gap behind the stainless. The screws that I managed to remove left different size holes in uneven locations. Everything is cleaned up now and the holes repaired.
Need a little advice folks,
I did manage to maintain the 1st, 6th and 11th clip locations, is there a specific spacing between clips or just best even guess between
1 and 6, 6 and 11???
Cruise-In III Veteran
macs65,
Here's a couple of pics of my '65 after I had POR15'd the windshield frame, then applied the 3M Glazing Compound 08509. If you look carefully at this first pic, you can count 7 clips (these are the replacement clips from Paragon) I installed in the original holes
On this 2nd pic (a little blurry), you can see another 4 clips. Note the relationship of the clips to the inside brackets for that black trim piece.
Hope this helps.
Oh, when I did mine, I found 12 clips around the base (I ended up using 1 of the original ones.
Regards,
Jim
In God We Trust!
Hope this helps.
Regards,
Jim
In God We Trust!
