66 backup wires.
Old 12-15-2014, 10:14 AM
Culley16
4th Gear
Culley16's Avatar
Default 66 backup wires.
I am installing a 5 sp Tremec this week (hopefully), the 66 had a Hurst shifter installed, who knows when! My problem is I can't fine the wires running to the backup lights, any suggestions?
Thanks, Culley
Old 12-15-2014, 10:29 AM
65GGvert
65GGvert's Avatar
Received 3,220 Likes on 2,302 Posts
There's a two pin connector just below the master cylinder and slightly toward the center of the car. One wire is pink and one is green. Those two wires go to the backup light switch on the transmission. When in reverse, that switch shorts those two wires together to light your reverse lights. The actual wires to the backup lamps run in the harness. If they currently work, you only have to work with the wires at the transmission switch to make them work with your new transmission.
Old 12-15-2014, 10:33 AM
65GGvert
65GGvert's Avatar
Name:  backup connector.jpg
Old 12-15-2014, 04:01 PM
Culley16
4th Gear
Culley16's Avatar
Default 66 Backup!
Thanks, 65GGvert. Really appreciate the help! Will check out tomorrow!
Culley
Old 12-15-2014, 04:44 PM
Culley16
4th Gear
Culley16's Avatar
Default 66 Backup wiring.
Thanks, Culley
65GGvert.
Thank, very much appreciated! Will check out for connectors tomorrow!
Again, thanks, Culley- Charlotte, NC
To 66 backup wires.
Quick Reply: 66 backup wires.
