Question on new door panel install.
Starting to get my plans in place for installing the interior on my 65 and have a "what works for you guys" question.
The Corvette America Deluxe 65 Door Panels come without the door lock or window crank holes pre drilled. Before I start hacking away on a $500 door panel I would like to know what tool you guys have used to cut these holes in with.
Thanks, Dennis
Thanks, Dennis
Received 6,943 Likes
2015 C2 of Year Finalist
I used a hole saw slightly bigger then the shaft.
A stepped unibit works nicely
Dennis:
The trick with the hole saw (for the window crank) is to run it BACKWARDS --no snags.
For the lock **** (and the screw holes under the armrest), I use a heated prybar (the kind with the tapered round shaft) to burn the hole. As the vinyl melts back, it gives you a kind of reinforcement ring. Much less likely to tear, compared to cutting the hole with an X-acto. This trick (with a Phillips screwdriver) is also the way to make holes in your carpet. No loose fibers to get wound up on the screw.
FWIW - Mike
FWIW - Mike
Thanks everyone for the tips.
