1965 L78 motor mount issues
C2 of Year Finalist (stock) 2019
hi there everyone, i have got my motor and trans bolted together and setting it in the car. i bought corvette central motor mounts and i seem to be having issues with them...they seem cheaply made !
i had a heck of a time getting the bolts threw them, and just a plain pain!!
i finally got them bolted and my motor sits crooked in the car. the trans mount is way off and will not bolt up.. now mind you this was a running driving car when i took it apart. i screwed up and sold my original mounts in a box of left over parts. does anyone have a part NUMBER of a mount that is proper and will fit??!! for both engine mounts and a trans mount?? PLEASE HELP!!!
Long Island Corvette Supply
Engine Mount (original) / 38-01A / $35.00 EA
Transmission Mount (manual + Auto Trans) / 38-05 / $12.00
Received 1,843 Likes
Some pass car mounts looked similar and were close dimensionally but you had to force the bolts in and the engine wouldn't sit in it's cradle.
GM #3846466 is an old number. Looks like the number has been superceded to 3796050 but you need to check it out.
Your frame isn't bent by any chance, is it? If the mounts are bolted to the engine and to the frame, your transmission mount should drop very close to where it belongs without forcing anything.
I think all midyears regardless of engine size used the same engine mount. The engine mounts were the same as 409 pass car, '61-'64 and many BB/Z 28 Camros, BB Novas, some 350 Camaros, etc..
About all replacement engine mounting is made offshore and the parts I've seen in the last ten years really look crappy compared to OEM.
Best to you,
Al
I consider myself a novice. Something else is wrong! I bought my replacement motor mounts and trans mount at O'Reilly and no problem with alignment. Also just replaced the horizontal motor mount bolts with ARP bolts with engine in car. I don't understand what is going on here. I still have my old motor mounts if you need them. 1966 327/300.
Best to you,
Al
Best to you,
Al
THANKS APV,these mounts i got from paragon look really cheap very thin metal, and one was even bent at the ears! a pr of plyers fixed it. they did not bolt to the block right, i had to do a lot of jiggling to get bolts started into the block, then you could get one side bolted up, but the other side would be a 1/2 in of from alignment! i put a tappered drift pin into the hole and pushed it around enough to get a bolt slid thru.. i have a pr of NAPA mounts coming in the AM friday so im gonna try those and let everyone know.. i may have to take you up on your offer, who knows?! LOL thanks again
Thank you,
Al
Received 6,945 Likes
2015 C2 of Year Finalist
if your not building a NCRS car I would use the 69+ LOCKING motor mounts for safety you can get them at any auto parts store
Maybe not a bad idea but the Corvette style mounts were not a problem anyway and weren't recalled along with the millions of pass cars that had a different design. Besides, you'll run into an interference problem on the ignition shielding if you use the later mount.
not a BB
I found this pair of Anchor original style mounts at my local Summit Racing about two years ago. This pair was made in the USA, fit perfectly and even cured a vibration problem I had. I did have to trim some rubber casting flash. They still list them in their catalog for just under $9 each.
YES this is a l78 396 car...i will check on those anchor mounts.. thank you..
i hope that the NAPA mounts are going to correct, we will see..
the car is not bent, or damaged in any way..i believe it is just a poor china made peice!!! molded crooked, that is what im thinking...very disipointing coming from paragon i have gotten great stuff from them....im not doing a NCRS but im going about this peice by peice so that the least amount of change will have to take place to get it there for me or the next lucky person if the price is right....LOL
thanks again everyone
WELL, i recieved my new NAPA mounts today, and the fit perfect!!
the motor sat right down on the frame and the bolts slid right in..trans mount bolts went right in also. so it for sure was a faulty set of mounts from paragon..bummer i threw the boxs out already i guess i will have to bite these...thanks again guys
Just curious. Did you happen to notice if the mounts had the same part number molded into them and pictured by Mike67NV? It wouldn't surprise me if they did..
yes they did have the same number on them!! but not the same way, it was a little smaller...i was beginning to worry, i had the frame powder coated. and started thinking they GOOFED something up...im cool now..no issues...
