Recommendations for a good tuner in/around SW Oklahoma
Received 9,518 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
My '64 is running rich and adjusting the carb is beyond my knowledge base at this time. I'd like to find someone with Corvette knowledge and experience to take the car to. Is there anyone around me or near me? Any recommendations? Thanks!
Merry Christmas, everyone!
2015 C7 of the Year
No need for a 'Corvette specialist' as the carb/engine combos are fairly common across the Chevrolet line at that time. A competent mechanic should be able to supply your car with a fix. You don't state which carb/engine option your '64 has. Where in Oklahoma do you live?
The backfire probably wasted the power valve in the carb causing your richness. To test whether the valve is bad is to plug the front carb vent while the engine is running. If the engine stalls the valve is defective.
2015 C7 of the Year
I'll test that. Is there a good diagram of the carb parts that I can reference? I basically no nothing on what is what on the carb at this point, but want to learn.
Hey fellow Okie!
Don't feel alone. We are here with you.
Some very knowledgable folks on here. You can do this
Wish you were a little closer to Yukon. Shop full of guys over here.
My advice is to provide as much info here as possible and include pics.
Looks like you have a Holley carb rather than a Carter which was original to a 327, 300hp for 1964.
We are lucky to have a top notch carb guy in Ok that can help you with repair and tuning.
How was it running prior to this insident?
Would be great to meet sometime.
2015 C7 of the Year
Hey fellow Okie!
Does sound like the power valve is blown. If you keep driving it while it's running way rich, you'll foul the plugs to the point where it won't run, so I recommend that you don't drive it until it's been fixed. As they say a lot on this Forum, "Ask me how I know!"
OK, that exhausts MY knowledge. Welcome to the community. and good luck.
Steve
Received 1,858 Likes
Looks like (someone will correct me if I'm wrong) you may have the intake manifold for the L76 365 HP solid lifter engine and a Holley 2818 carb as used on both the 1965 L76 365 HP and the L79 350 HP hydraulic lifter engine. The direction the oil filler pipe is angled (toward the passenger side) and the style of cap are what make me think it's the L76 manifold.
Ok, call Richard Simon in OKC area. 405-650-7644. Be sure to provide all details on the exact carb you have. Hope this helps.
2015 C7 of the Year
Thanks to everyone for reaching out to help!
2015 C7 of the Year
