body dolly, mounting holes
Received 6,943 Likes
2015 C2 of Year Finalist
According to that picture it's 70.93
Be careful, I think the wrong dimensions are being picked up off the drawing above.
I measured 55.25" from center of hole from mount to mount at the firewall (#1 referenced in OP's drawing). I think #1,2, and 3 mounts make a perfect rectangle, so #2 and 3 should also be 55.25" apart, or very close to it. I'm assuming you haven't taken the body off yet, otherwise you can simply measure across from mount to mount once the body is off the chassis.
Rick, the 44.76 dimension is the frame width at the rear end of the chassis, irrelevant. The distance from #1 to #3 is 69.18", no need to subtract the 18.02.
He's building a body dolly and is only concerned with the body mount distances on the birdcage, #1 and 3 mounts. It has nothing to do with tire width, etc. I've measured the 55.25" dimension off my own car and had others do the same. Hope this helps.
Yogi
Received 1,857 Likes
The "red line" dimensions (left side body mount frame bracket hole center to the corresponding right side body mount frame bracket hole center) are as follows:
#1-2-3 - 55-1/4"
#4 - 49-1/4"
#1-2-3 - 55-1/4"
#4 - 49-1/4"
Last edited by JohnZ; 12-27-2014 at 06:22 PM. Reason: Corrected dimensions & typo in 1-2-3
The mounting holes are centered in the rockers, both rockers are parallel to each other, so how can mounts 1,2, and three be different dimensions? I'll stick with my 55 1/4" dimension and let the OP decide which is correct. See below, 27 5/8" x 2 = 55 1/4".
Ken is correct - these old eyes were looking at a '68-'69 frame diagram for my first set of dimensions, and they were different than '63-'67 due to the "coke-bottle" body shape. I went back and edited my post to reflect the correct dimensions, which are shown in Section 2 (Frame) in the '67 Chassis Service Manual.
Yes thanks.
Thanks all for your contributions. Where I live there is no reference C2 coupe at hand to compare, so this forum is where I need to find what I am looking for. It's great! Just got my NCRS membership documents! Although I am not going for a ncrs type restoration, it's one more source for me to rely on. And there is a nice bunch of ncrs club members in Holland, the country next to mine.
I guess John the first dimension needs some mere editing?
Plans for the rotisserie/body dolly
I recently purchased a 63 fuelie convertible. To do the restoration justice, I plan to do a frame off. I have been looking for a set of plans to build a combination body dolly and rotisserie and I found the photos of the blue rotisserie at the end of this thread. It looks exactly like what I hoped to build. Do you have the plans and materials list that you could provide?
